BX parts for sale - UPDATED new parts added Friday 8th April
- electrokid
- Mike E (uk)
BX parts
Hi,
pipe seals, 3.5mm 8 off
pipe seals, 6.6mm 2 off
sump washers, large petrol 5 off
Front Disk pads.
Will pm later.
thanks,
Mike
Front Disk pads.
Will pm later.
thanks,
Mike
BX Parts for sale updated 29.02
Dear David.
Please could you kindly David put my name to the following :-
1/ 10 Sump plug washers at 30p each.
2/ The bonnet lock at £ 5.00.
3/ Air hose 1.6 i at £ 15.00.
4/ Engine mount R/H at £ 5.00.
5/ Engine mount at £ 5.00.
6 The interior lamp at £ 3.00.
Many thanks David once again.
Vince.
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
BX Parts For Sale updated 29/02
Dear David.
Thanks so very very much indeed David
PM sent.
All The Best David.
Vince.
PM sent.
All The Best David.
Vince.
Hi David. Can you put me down for:-
Large petrol sump plug washers x20.
BX 16 valve exhaust gasket.
Many thanks,
Mark. Pm sent.
Many thanks,
Mark. Pm sent.
- barry badger
hi David
I have put together a list could i have whatever you have left out of these:-
1336g4
95598511
51472
23614 x2
1307w4
thermostat housing gaskets 1 pack
estate rear lens 1 pair
many thanks
Barry
1336g4
95598511
51472
23614 x2
1307w4
many thanks
Barry
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
Bit late to the party here as I have only had my BX since 29 Feb!
David, not sure if you will be posting any more goodies up here, but if you have an air intake hose and boot catch for a Mk 2 TZD hatch, I'd be interested!
Thanks
Thanks
- barry badger
Hi David
Could I please have any of these that are still available:-
the rear caliper pin kit
51472 crank seal
23614 cam seals (2)
32622 crank seal
1336g4 water unit
all of the metal pipes listed
4 of the large pipe seals
4 of the small pipe seals
many thanks Barry
pm sent
51472 crank seal
23614 cam seals (2)
32622 crank seal
1336g4 water unit
many thanks Barry
pm sent
Hi David,
do you have the following available please?
BX brake pipe doser valve to safety valve (96093542) x2
BX brake pipe front left hand caliper to union (95596539) x1
BX suspension pipe - front suspension cylinder Rh to union (95600541) x1
BX brake pipe LH rear from caliper to union x1
£10 for the lot
BX suspension pipe union (5447189) x 2 - £2 each
BX reverse switch 16v diesel & turbo (225741) - £4
Are you going to the X rally by any chance? It would save on postage if possible, i'll pay you via paypal as a gift in advance of the meet?
Matthew
£10 for the lot
Matthew
