possibly wanted
barry badger
possibly wanted
Post by barry badger »
I might be needing a really good tzd engine, short motor or piston set. I will know for definite tomorrow.
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
Hi Barry
This engine of mine is still available but you would need to take it out & soon.
http://www.bxclub.co.uk/forum/viewtopic.php?t=15642
read down the thread for engine details. parked at BL4 Kearsley, Bolton
barry badger
IS this the same engine as in a tzd?
It's the same engine as in a TZD Turbo (as well as RD Turbo, DTR Turbo and TXD Turbo), but not the same as a 19TZD. Citroen only fitted one turbo diesel engine to the BX, so if yours is a turbo, this will fit the bill.
barry badger
That engine sounds brilliant, I'm not sure what to do at the moment, whether to put my car into the local diesel specialist in the hope that i've missed something or just replace the engine. I will let you know in the next 48 hours. If I want the engine is this weekend ok?
barry badger wrote:If I want the engine is this weekend ok?
I won't be about but we have 24hr security who will let you in.
barry badger
Compared compressions between both of my tzds, the one that is a poor starter has compressions between 320 and 360psi. this engine has done under 93,000 miles. The compressions on the other one that runs fine are all on 380 psi, this engine has done 150,000 miles.
so I definitely need an engine.
Kevan I have sent you a pm regarding your engine.
sdelasal
Post by sdelasal »
Those compression figures don't seem bad compared to the 'good' engine... What is the spread across all 4 cylinders ? What does haynes say is the spec & service limit? Hot/Cold? I think 450psi new is typical.
I had a poor starter once that had a lot of blow by too - 200PSI in two of the cylinders - once warm it ran fine though. New rings curred it.
barry badger
I didn't know what compressions I was looking for so I compared it to a known good engine. Although there isn't a drastic drop in the compression it makes the car irritating to drive. If the engine is hot and I nip in a shop for 15 minutes or so it needs 5 seconds of the glowplugs to start cleanly and when it's cold it starts ok but hunts and emits blue/white smoke for about 10seconds. I enjoy every jouney in my bxs even my 1 mile commute to work but this problem makes it a chore.
The cylinder results were:-
cyl 1 320psi
cyl 3 360psi
cyl 4 320psi
I didn't do No 2 because the injector pipes were in the way but the results from the others confirmed my fears.
sdelasal
Post by sdelasal »
Barry - I just checked Haynes and it says min hot compression is 260psi, normal is 360-430psi. Maximum difference between two cylinders is 73psi. With mine, I need to let the glow lamp go out and then I wait until I hear the 'click' from the relay box - it then starts clean. If I try sooner it can be a bit lumpy/smoky at times. I plan to check glow plugs, check valve clearances and finally swop injectors for a know good set. All three of those items can contribute to a smoky start. Steve
Sounds like your engine is within tolerance afterall, thats a nice bonus :D Perhaps as Steve has suggested, there might be other areas for an improvement in running performance?
x 151
I agree with mulley they sound within tolerances to me .
CGATCX25GTITURBO
Post by CGATCX25GTITURBO »
I had starting troubles with a 15D AX... did the valves clearances and it ran perfect after that.
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
