Turbo diesel rad
http://www.bxclub.co.uk/forum/viewtopic.php?t=15858
This was still for sale, I was going to buy it as a spare, it is a recore as new?
- x 4
So was I, but no replies to PMs...Defender110 wrote:http://www.bxclub.co.uk/forum/viewtopic.php?t=15858
- Vanny
BX 16v Ph2 - XPO - x 82
Erm, not sure what you mean about the intercooler, you should find it located on top of the engine, just like a 405 TD or a 309 TD like what this rad is from. Other than that i think there pretty much the same. The outlet from the bottom of the rad is slightly angled, making it easier to fit the big hose on, and there is an extra 15mm outlet which is normally blanked off, but then the valver has that too.
I can always russle up a picture if you can't find a better option!
EDIT
It's this rad, apparently it's 10mm wider and 10mm shorter, and i think it has a thicker core too.
http://www.carcooling.co.uk/index.php?p ... rsion=true
compared with a BX td one
http://www.michelecaroli.com/radiators/ ... sp?id=3407
EDIT
Andy meant oil cooler and the one on his car is similar looking to the second link in your post Vanny, and the OE No. 95635181 is the same,
although service citroen also list a factory exchange unit part No. 1331.JL,
bz td rad
hi i have one for sale on ebay now in lpool bye
hi i am rob in liverpool 1989 bx 17 dtr turbo
