357-955-531 as per my earlier e-bay link.electrokid wrote: Any chance of someone finding out the VW part number ?
Ordered yeaterday afternoon and dropped onto my doormat this morning, all fitted and working a treat
Mike E (uk) wrote:improved wiring to starter motor & headlamps & ignition coil, + twin cooling fans. These I have done.
Mine's pretty close, and above about 2000m altitude probably has the edge over a 16v!messerschmitt owner wrote:I'd like a BX with the go of a valver and the economy of a dizler.
Surely the lower oxygen-density at higher altitudes has a negative effect on a turbocharged car, or does the lower temperature counteract the effect?mat_fenwick wrote:Mine's pretty close, and above about 2000m altitude probably has the edge over a 16v!messerschmitt owner wrote:I'd like a BX with the go of a valver and the economy of a dizler.
