300000
Re: 300000
Definitely, the prize is to drive it until it reaches 300000!
The lowest miles I've ever had on a car was a N reg Golf TDi estate, think it was around 86000.
My first car, another Golf (1.4) had 143000 when I got it, put it on to about 185000. That felt like it had done a lot more,
and I didn't know you needed to change oil and things like at the time, it didn't even have a thermostat and the clutch cable
was tensioned with gaffer tape and rope! How it coped with those miles I don't know.
Martin
- citro-geoff
- My Cars: Xantia VSX Estate-146K-1996 (The wifes car)
BX TZD Turbo-317K- Awaiting repair/donor car(broken subframe)
BX TZD Turbo-202K-project car ongoing
BX TZD Turbo-212k-One owner car rescued from being scrapped.
2CV Charleston-101K-One owner car awaiting restoration.
ZX Memphis-185K-Wifes daily driver.
Re: 300000
Glad the BX is still going strong and you still like it.Missed it when I was doing the 2012 Challenge,the ZX was a bit bumpy to say the least!! Have you checked the drop links for the noises on the front,a common problem,or it could be a bottom ball joint.
1995 ZX Memphis TD Saloon 176k
1997 XANTIA VSX ESTATE-112K(the Wife's!!)
1993 BX TZD Turbo Estate 202k waiting repairs for mot.(Just started to fix it!!)
1985 2CV 100k - waiting full restoration.
- x 150
Re: 300000
Good to see you back here Geoff, does BX ownership beckon again......
Re: 300000
Hi Geoff. And BX's don't boil their brake fluid Are you going to the ICCCR?
Re: 300000
Congrats! I've just clocked up my 100,000th mile in my 2CV (189,500 miles in total). BX Mk2 is just behind on 187,000. Mk1 is on 231,000 so 300,000 still a long way away for all of them!
- JayW
- x 13
Re: 300000
Good luck with that... the TGA's are awful...mds141 wrote:Hope the MAN units prove to be as durable.
