WHEELS wanted
WHEELS wanted
WANTED: Four in number steel wheels for BX
- x 151
Re: WHEELS wanted
Hi Eoin
You will be after the silver solid type wheels for your TGS not the black vented later type.
I have some but I'm quite far away.
Re: WHEELS wanted
Tim,You are on! My spare wheel I will lower and check tomorrow a.m. Certainly silver and I know it sounds daft I want to check it is solid - 99.99999 % sure they are! I ll have the answer to you by 1200! O******l is a doddle for me - back in the 1970s I was doing Bath to Roll Royce And Associates (the nuclear reactor division RR) in Derby once week in my 1015 GS I ll ring you and fix details. the wheels are to mount the original 1991 tyres on.
- x 151
Re: WHEELS wanted
Ok Eoin, you will need to refurb them but they will do the job.
I am in London on July 15th if thats nearer or Silverstone this Friday.
Re: WHEELS wanted
H Tim, Half an hour late 1230 not 1200! Yes please! Silver and solid they are! I ll ring you! I will be having my priority list of items including the cam belt done when I collect my GS at Chevronics when it arrives back from Harrogate and until then am deliberately limiting use of the BX so I will pay you NOW and fix collecting soonest if that is OK. The thought crossed my mind... how about Stratford at the Midlands Rally as you will be there for the CCC AGM? I will be using the BX for that run...
- x 151
Re: WHEELS wanted
Hi Eoin
Sadly cant make Stratford this year due to work but can get them there im sure.
