BX 2.0 CT Turbo, it begins....
BX Bandit
Backslash Bandit
My Cars: Cars
Re: BX 2.0 CT Turbo!
Post by BX Bandit »
MULLEY wrote:Is this a mid-life crisis mate???
That made me laugh. Not at you Tim, but at the brash-ness of Mulleys question......
Using Hiliary's mph/1000 rpm, then with the TD box, the TCT will be doing exactly the same rpm as the TD engine. e.g
at 50 mph in 5th the engine will be at 1901 rpm
at 70 mph in 5th the engine will be at 2662 rpm.
For an N/A petrol I'd say forget it and that was probably the thinking behind not using a TD box. i.e. all your tourque in a n/a petrol is 4000rpm ish (not knowing ANY modern petrol engine), where as the bx TD is 2500, which make acceleration in 5th from 70 pretty comfortable.
However, yours will be a Turbo Petrol, and so the TD gear ratio's are more favourable, however, I don't know what the power/torque curve of the TCT is, but my guess is the TD box will leave you a little sluggish from 50 (there's always 4th gear though) but probably otherwise ok.
The guys from romania mated a BE3 to the 2.1td, using an uprated clutch. I'm not sure about the flywheel but they clearly achieved a good outcome.
Using the overhead i/c is probably too small at my guess. You've got more flow and thus more heat to dispose of and I'd be very surprised of the TD inlet manifold will fit the TCT. You could of course get one made. If you search around the internet, there are various 'calculators' that will help determine the size of your intercooler, helping you decide if the TD I/C is sufficient.
At the least I'd say you need vented discs. The valver discs are common with early Xantia of the D and I think TD variety and as early Xants had 14" wheels they should fit behind standard BX wheels (don't know for sure). The Xantia calipers have a bigger piston, so more braking effort, but then you really ought to have stiffer spheres (TD/GTi spec i.e. 400cc) unless you're very sure to slow up well for the corners. The TD/16V anti roll bar should go in the front (what spec car are you putting this in?) and ideally a 16v anti roll bar at the back (although you'll need 16v rear arms or make a mod).
x 150
Thanks Neil,
The idea would be to fit 16v front calipers and discs just incase, I wont be throwing it round corners so will keep the standard BX set up, but may change the spheres for 16v ones, and it has 16v alloys on it already. The idea is to have a car thats a fast cruiser and not one to scream round hairpins in.
I was hoping to just use the TD intercooler and get hoses to connect that to the TCT inlet so I can use the BX under bonnet ducting and avoid fitting a front mounted one so I can use a standard BX TD rad set up.
If you want to keep the ride smooth, forget the 16v ARB's! Aslong as you're not too fussed about hairing around corners, I'd stick with something like GTi or TZD Turbo spec gear myself.
In answer to Neil's post, the TCT has a power curve very similar to a diesel. It wakes up very slightly later, though still below 3k RPM and will hold on longer. It's not a patch on a decent twin-cam for driving pleasure, but it's very easy to wind it up. Think of it as a TD, but much better to drive and alot more thirsty :lol:
x 150
Ive got a Golf 1.4 TSi at the moment, which only has 140bhp but has lots of low down torque and in every day driving is great, very smooth and punchy. If I could get something like that but with the beauty of a BX then I will be a happy chap.
mike st gilles
Post by mike st gilles »
Not to pour cold water on such a magnificent project....but have you thought of getting a quote for insurance on the beast in advance? These days anything non standard could be very hard to insure and you could find yourself paying more in insurance than you might for a 'standard' supercar or suchlike.
Just my tuppence worth........sounds like a monster of a project.
Mike
x 150
Hi Mike
I am aware of the insurance problems but know of a company that deals with modified cars so should be too much of a hassle.
Sureterm are good for modified and kit cars - I managed to Insure a Lomax as a daily driver with them no trouble.
Tim Leech wrote:Ive got a Golf 1.4 TSi at the moment, which only has 140bhp but has lots of low down torque and in every day driving is great, very smooth and punchy. If I could get something like that but with the beauty of a BX then I will be a happy chap.
A TCT will give you that. They sound crap and chew fuel, and they're pretty dull, but for what you've just said they're perfect.
x 150
I do less than 1000 miles a year in WTF Kitch, and im not that bothered what it sounds like, a cone air filter, dump valve and maybe a rear box may improve things!
Panel filter? Does fuck all for sound or performance. Drilling holes in the airbox has a much more dramatic effect on sound, and the main restriction of a standard air filter setup is the box and pipe work, not the filter itself. The only advantage to a panel filter is that it lasts longer. Great, only have to do 10 year's worth of servicing to pay it off then!
Dump valve, sounds good......if you're a chav!
Rear box.....maybe. Lack of a cat will improve it anyway, and with just a rear silencer you might bring out some turbo burble, but in fairness you want refined swiftness....keep it quiet like a Xantia!
x 150
I need an ecu and a front pipe if anyonr knows of any? Its for the earlier car with one coil pack and leads, and keypad immobiliser so the ecu will need to be unlocked.
Have a look on ebay Tim. I've also emailed you a link.
x 150
mds141 wrote:Have a look on ebay Tim. I've also emailed you a link.
Cheers mark but i cant afford or have room for another engine.
Kitch wrote:Panel filter? Does fuck all for sound or performance. !
We'll have to test this theory on the rolling road day, i'll bring along a paper filter & we can then play :) If i get half a bhp i'll be pleased, haha...
x 150
Re: BX 2.0 CT Turbo, it begins....
As you know the engine and box has arrived, I think Ive located an ECU but still need a Xantia front pipe, I will look at a BX TD one and see if it can be "adapted" if anyone has a spare I could borrow, if it can be made to fit of course money will change hands...I will need to fit the insert for a lambda probe though.
The Xantia one comes complete with cat though which I dont want.
I will shortly be removing the Xantia HP pump, Aircon pump an alternator, are these of any commercial value?
