pipe seals.
pipe seals.
anyone know where i can get some of the pipe seals for the short pipe that joins the pressure regulator to the fdv? had to pinch them for an emergency fix on a different bx and now dont have any. its a fairly large bore pipe, not the skinny ones.
- x 151
Re: pipe seals.
Citroen still stock them I think, someone will be along with a part number soon I expect!
Re: pipe seals.
I don't know what the deal is there in the UK but the Citroen dealer here has a box of them always to hand in various sizes,no need to order. They're overpriced for what they are though. I think €2 for a tiny piece of LHM resistant pipe that you can barely see!
Re: pipe seals.
'96085783' - Hydraulic LHM Pipe Seal for 6.35mm pipe £3.29 each + postage (£7.25) from EURO-CAR-CARE !Tim Leech wrote:Citroen still stock them I think, someone will be along with a part number soon I expect!
'OP', Going direct to you nearest main Citroen dealer will probably be the cheapest option on this one !
Also there's :- Pleiades, Unit 12A, Brookside Industrial estate, Sawtry, Cambridgshire, PE28 5SB, phone 01487 831239
Re: pipe seals.
here is price and part No. from citroen
96085783 HYDRAULIC PIPE LINING 2.69 GBP 3.23 GBP 3.23 GBP
at that price i would call
Martin at Pleiades on
01487 831239
01487 831239
- Vanny
BX 16v Ph2 - XPO - x 82
Re: pipe seals.
I used to get my pipe and seals from Bonapart 2cv before they where sold off over seas and became;
http://www.bonapart-products.fr/" onclick="window.open(this.href);return false;
€0.35 for a seal sounds much better! I seem to remember the new owners english is pretty good, so it might be worth bashing an email over the channel and see what comes of it!
- Vanny
Re: pipe seals.
Ah ha! they have a UK distributor
http://www.ecas2cvparts.co.uk/brake-pip ... -1300.html" onclick="window.open(this.href);return false;
Re: pipe seals.
cheers everyone. will get some and a couple of spares. thanks for the help.
Re: pipe seals.
Vanny, that's all well and good if your wanting a 3.5mm pipe seal (Which the /\ link takes you to) !Vanny wrote:Ah ha! they have a UK distributor
As this fella is after 6.35mm pipe seal (As per the OP) and after looking at the site which you have suggested it doesn't seem like they stock/supply them after looking thro' their SEAL-PIPE/UNION selection !
- Vanny
Re: pipe seals.
I was linking to the UK supplier of Bonapart products. Bonapart DO sell both sizes of the 6mm seal.RxBX wrote:Vanny, that's all well and good if your wanting a 3.5mm pipe seal (Which the /\ link takes you to) !Vanny wrote:Ah ha! they have a UK distributor
Re: pipe seals.
here is a link to Bonapart
select products then select the 11th option in the drop down menu
Re: pipe seals.
I'm getting a feeling of deja vu here...
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: pipe seals.
Re: pipe seals.
