Gary wrote:The BX umbrella
Ah yer just showin' off now Gary.
My Gti has 2 indicators below, one is the K light and the other the ABS warning light. The handbook shows the diesel tacho having a position for the ABS only although the back of the pod may have some commonality.David wrote: One thing I have always wondered about though; there is a space & wiring connections for a extra gauge/dial/clock under the rev counter, what was this? as I have never seen one fitted there.
That's a new one on me, too.michaelr wrote:And the hinged lids on the cubby holes each side of the load space.
I found some, newe old stock. Gleefully went to fit them and then discovered they were hatchback versions and the estate cubby holes are longer....deltic wrote:That's a new one on me, too.michaelr wrote:And the hinged lids on the cubby holes each side of the load space.
I like this. I have a Viking Tyres Umbrella but no one seems to find it at all interesting. Little bits of history that keep you dry.Gary wrote:The BX umbrella .
Damn and blast - we should have swapped!Mike P wrote:They did make a longer version for estate length boot panels.
I did the exact opposite of you, bought a NOS set from ebay and found they were too long for the hatchback. Went straight back on ebay and I as least I got my money back.
Mike P
I looked around for a pair - then I saw a picture of them and wasn't impressed so decided to make them - haven't got around to doing so yet.And the hinged lids on the cubby holes each side of the load space.
It's for the diff lock.As an aside on my GTi I have four blank switches in row between the seats - what are these used for? I only ever seeing one being used on a 4x4.
