17rd will only run flat out
- citsncycles
I managed to get Fred started today, old fuel and all, but he will only run full throttle, even with the sop screw wound all the way out. I don't think he's running away with his own oil as he shuts down as soon as I turn the ignition off, but I'm now at a loss as to what to try next. Any ideas?
- x 151
Re: 17rd will only run flat out
Hmm pump timng possibly Mike as per FB?
- citsncycles
I've verified that the belt timing is ok, but it has also bveen suggested on FB that I need to take the top of the pump off to check that the arm on top of the pump is doing its thing.
- x 88
17RD does nothing unless flat out shocker
- Thread Bear
Does sound like a physical prob like something stuck open. Only time I had this was a miss assembled set of levers on the pump meaning it could not shut off. One part was on back to front but I forget which. Pug, but same bits. No idea how it had been driven. Slipping the clutch I suppose.
Yes just sounds like the fuel rack is stuck open, which pump is it?
- citsncycles
It's an early Bosch pump, same as Timex. I've bought a seal kit which arrived in the post today, so I'll be pulling it to bits tomorrow. With all the bits and pieces I'm finding seized up I'm expecting to find more stuff that's stuck. 14 years stuck in a field will do that I suppose.
- Thread Bear
It didn't do me any good either, and the birds kept away the whole time. Bummer .citsncycles wrote: With all the bits and pieces I'm finding seized up I'm expecting to find more stuff that's stuck. 14 years stuck in a field will do that I suppose.
- x 151
Any further forward on this Mike?
- citsncycles
Not yet - the only dry day I've had off work since then I had to service both Timex and the Vara, then guess what - it started raining!
I'm on lates this week, but may get a chance to look at it over the weekend after my shift finishes.
- x 151
Know what you mean Mike, fed up with this rain , the link road from our new estate to the A444 is under. 2 foot of water which means an extra 5 mins reroute.
- citsncycles
After work yesterday I actually had some daylight and dry weather, so took the top off the pump:
Not much wiser as a result though! I assume the gear is driven off a shaft driven by the cambelt. The levers at the other end move, but I don't know if they move enough! They seem to press against the shaft that the gear runs on - is that supposed to slide or something? Thefact some of it seems to have a light coating of rust doesn't exactly fill me with confidence either!
I'd say the colour of those internals does not look good. Looks like rust has got a grip! It's all supposed to be spotless and clean inside there. I'd suggest look for a good used pump and swop it over. It can be done by leaving the belt wheel clamped in place to the engine - that way cam belt is not disturbed. Steve
- citsncycles
I must admit I did wonder about that. Does anyone know how common Bosch pumps were on the XUD engined C15's, or if there would be problems fitting a Bosch pump from a 19d? I'm only asking about Bosch as that would avoid changing the pipes and injectors.
Hmmm - also wondering what the cost may be - might be more cost effective to drop a complete engine with a pump fited if I can find one - 19td Mk1 anyone???
Mike - The difference between the xud7 & xud9 is 1770 vs 1900cc. So the 1.9D pump will tend to put in too much fuel at a given RPM. However, I believe they are to some extent self compensating - so for example, at idle the pump will adjust fueling to get the RPM correct - so if you fit a 1.9 pump , it'll back off the fuel as much as it can to control RPM. Then when you go on the pedal, fueling will be relative to that idle adjusted position. There will be limits to how much it can back off. However, there is also a fueling adjustment screw that you can adjust to take out some of the excess fuel capability. So given there is only a 130cc difference in engine capacity, I think you'd get away with a 1.9D pump and backing off the fueling screw. ebay item 281264629052 might do the trick. If its from a turbo engine though that adds another layer of maybe! Steve
