Octopus
Phil Brook
Octopus
Post by Phil Brook »
Does anyone know where if at all I can get a new octopus? My mechanic has treid but no luck and so is having to repair the existing with new tubing. Trouble is one leak gets fixed and another springs out. The car has been mainly off the road for about 9 months- could inactivity hasten the dreaded rubber rot!!
Philbrook
Re: Octopus
Where has he tried? People have been getting them from dealers fairly recently, but it often helps if you give them the part number.
Stinkwheel
Re: Octopus
Post by Stinkwheel »
Citroen dealers should be able to help if you give them the part number as Mat rightly said, another option is to phone chevronics, as i believe they have them in stock at around 63 quid plus postage.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Re: Octopus
If you're enquiring by description it's probably best not to ask for octopus to the uninitiated, but 'leak back harness' which is the name given by GSF and other factors.
They used to be available for £27 from GSF but are no longer listed online. I'm not sure whether the rubber quality on these is/was better than the appalling quality of the rubber of their strut returns. :?
Re: Octopus
Good point about Chevronics - they mentioned they had a batch in (picture from Facebook) on the 12th May!
Re: Octopus
I'll have that one in the middle!
Re: Octopus
Good, cos I was going to go for the 2 on the right
Phil Brook
Re: Octopus
Thanks all I should have remembered Rob Moss
Philbrook
Re: Octopus
Post by Tinkley »
The GSF ones were actually OK, in genuine Citroen bags and Made in Poland. I got one for about £12 as they were binning them at the time - 2010 I think, maybe 11.
Unlike the Spanish made front strut returns grrrrrrrrr.
x 137
Re: Octopus
Also known as a back harness on parts listings.
Re: Octopus
Post by citronut »
rutter123 wrote:Also known as a back harness on parts listings.
oil back harness :twisted: :roll: #-o :wink:
here is Rob's ebay listing
http://www.ebay.co.uk/itm/151183081523? ... EBIDX%3AIT
David
x 47
Re: Octopus
Post by David »
When mine broke, I made one.
I measured the diameter of the pipes (there were 3 different sizes from what I remember), Ordered some "oil & fuel hoses" in the appropriate sizes on Ebay, Then ordered some 'T' & 'Y' connectors & plugged everything together. Some of the pipes that needed to go together were the different diameters so I soaked them in hot water so they would go on the connectors. I can't remember if there were 2 or 3 different pipe circuits (your original octopus will tell you that).
So far it seems to be holding up well.
B-Hive
Re: Octopus
Post by B-Hive »
what about
edited: as above two posts before
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
Re: Octopus
I thought we had decided there were 2 or 3 different types of octopus dependant on year / power steering etc?
Stinkwheel
Re: Octopus
Defender110 wrote:I thought we had decided there were 2 or 3 different types of octopus dependant on year / power steering etc?
Thats very true, although i believe only the late RP numbers octopus is available now, if you have a non -PAS car themn its a case of plugging up one line.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
