wanted nearside bladeset rubber/ top end speedo cable
it is the rubber that joins the end of the bumper to the wing sometimes called a z rubber approx. 2 inches long and also top end speedo cable for a 93 tzd
- Mike E (uk)
Re: wanted nearside bladeset rubber/ top end speedo cable
It this the black plastic 'slug' with a D for droit on it what you want?
I can help you with the top speedo cable from a 92 tgd should be same.
