The intermittent wipe and self park on the tzd have stopped working although the washers and normal wipe works... but doesn't self park.
Fuse or relay or maybe a stalk?
Thanks
Wiper Issue
- x 151
Wiper Issue
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 52
Re: Wiper Issue
Could be the switch or maybe corrosion in the connector at the motor or the parking switch in the motor.
Re: Wiper Issue
I got wiper stalks, relays, motors if you need one Tim.
Re: Wiper Issue
If this is a series2 I would suspect the Wiper relay.
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
Re: Wiper Issue
On the fuse box? There is certainly a clicking sound on mine when on intermittent.
Re: Wiper Issue
Does make you wonder if water is getting into the fusebox...?
