Free Citroen Bx GTi 4x4 and 4x4 Estate cars available........
- Jaba
- x 83
Re: Free Citroen Bx GTi 4x4 and 4x4 Estate cars available........
Kevin, I am afraid my photos of the estates are the same quality as yours, so not worth posting.
You have done a good write up and description of all the cars. If you need any further help then let me know......
- My Cars: Gti 4x4 weekend car
Tzd spares car
Tgd garaged
Vectra Sri everyday driver
Gti 4x4. Project car - Contact:
Hy, any 4x4,s still available. Thanks
Would like white 4 x 4 if available. If no others want them I would take red one as well and prob make one from two depending on condition of the cars. If they are good then perhaps take the battered estate for spares for those 2. Mate interested in Bond Equipe, Herald and bikes if they are up for grabs.
OK, its been a while, so time for an update on this thread.
By the end of today, both of the Ford Cougar cars will have been removed from the site, and access is now much improved.
A key and the logbook have now been found for the white Bx.
I remain optimistic that keys will be found for the rest of the Bx cars. Though from memory I am fairly sure that logbooks are not present for the remaining 3 cars.
Now the bad news, having cut away some more vegetation from around the two estate cars, they have both got fairly advanced rot on the outer sills, and it is starting on the inner sills of the estate car that does not have a dent in the roof.
Fortunately the hatchbacks do not seem to be affected nearly as badly, and rust on the o/s sills of both is mainly surface rust and minimal at present, I have not yet been able to look in the boot area of the hatchback cars (another well known rot spot area)
I will once again be contacting those (via PM) that have expressed interest in these cars to confirm who wants what, etc.
The Red Gti hatchback was collected yesterday, and after some hedge cutting work and replacing all 4 of the flat alloy wheels and tyres with some steel wheels and tyres that held air, recovery was relatively easily despite having no keys.
This car may even go back on the road at some point in the future, as a more detailed inspection under the car once up on the car transporter revealed it to have far lees body rot than was previously thought. The only downside was the exhaust system which was as expected beyond repair, though the downpipe may be recoverable with care.
Arrangements will now focus upon removal of the White Gti 4x4 hatchback, for which I already have made provisional arrangements with another forum member to take this car on.
OK folks, time for another update.
Both the GTi 4x4 Hatchbacks have now found a home, and their new owners have even had them running.
Unfortunately no takers as yet on the two 4x4 Estate cars, so if anyone can take these on it would be a good result all round.
Both cars are now mobile, as I have replaced the wheels and tyres with ones that hold air, and the ignition locks have been removed, so both these cars can be pulled up and onto a trailer.
The site has now been extensively cleared, and access is much improved from what it was at the start of this project
Time is very much running out for these cars as they are now the last cars but one left on the site, and if there are no takers then its a certainty that they will be collected by the scrap man, after I have stripped them of the 4x4 parts As before if your seriously interested in taking on one or both of these cars, then send me a message via the PM function on this forum.
- x 88
I hate the idea of a rare car getting scrapped, but I'd be interested in the front wings, doors and bonnet (if straight) from the best example respectively, plus many interior bits. I'm reluctant to have the cars collected purely for me to break them, as it'd break my heart.
I wouldn't have time to restore either of these, but they'd help my mk1 TRS and another red ph2 16v that I have find a hope of seeing the road again.
- barry badger
Does anyone know what has happened to the estates?
I have sent Kevin a pm.
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
- Jaba
- x 83
I know he would be delighted if you are interested in taking one on. I am sure he will get back to you.
Time for an update on this thread.
Having just returned from holiday, all of the cars including the two Citroen Bx 4x4 Estate cars have now finally left this site, which happened in the last week of November.
After been severely (and I mean severely ) messed around on the Citroen Bx Facebook page by persons who promised to collect these cars, then ducked out at the very last minute, I regrettably had to let the rougher example of the Estate cars go for spares, and it went to Chevronics, who were honest about what they intended to do, i.e. break it for spares to keep other examples running. So anyone needing unique 4x4 spares could contact them directly.
The remaining 4x4 Estate has been moved to a near by temporary location (at my expense), and is still available for anyone who is seriously interested.
The property at which these cars were located is now on the market, hence the last minute push to get these cars away from here.
Compare and contrast the photos at the beginning of this thread, with the estate agent photos: https://www.zoopla.co.uk/for-sale/detai ... 2013bc53ec
In the last photo you can see the Bx that went to Chevronics for spares.
Finally is anyone up for any of the following: Citroen Bx Turbo Diesel hatchback white (bodywork looks quite good, apart from light accident damage to NSF door, front wing, and inner wing liner. The engine starts easily with no smoke after warm up, goes up and down on suspension, and with no obvious LHM leaks), Ford Cougar V6 cars x3, and a Ford Escort Chairman van (bodywork reasonable for age, fitted with a 1300 CVH complete with the dreaded Ford VV carb. All of these are another batch of vehicles that need clearing from from a location in Pangbourne (where the A329 runs alongside the Thames) in the very near future, who are also owned by the same person as the the BX 4x4 cars.
Barry Badger
If you get no joy on your parts requirements with Chevronics, then PM me again, as I have amassed a qty of 4x4 spares over the years.
Barry Badger
- Jaba
- x 83
Kevin, its good to read a happy ending (mostly) to this challenging task to save some unique BXs.
Its all credit to you as just the thought of clearing out the totally overgrown garden would have deterred most people from even thinking about taking this on. I hope you can drum up some final interest in the last one remaining despite your FB experience.
That house looks almost desirable now. I didn't realise it had a garage at the back due to the 10 foot high brambles.
Happy BXing new year !
- My Cars: Looking for a BX
1996 Toyota Celica GT
1960 Land Rover 88"
1999 Kawasaki ZX9R
1998 Citroen Xantia HDi 109 Exclusive Estate
Hi Kevin. I've tried PMing you, but I don't think it has gone through. Can you check please and message me back if not?
Regards,
Angus
Regards,
Angus
First car - 1996 Toyota Celica GT (Black) - Still going
Second car - 1996 Land Rover Discovery ES V8i (Green) - Gone, but not forgotten
Third car - 1960 Land Rover 88" Petrol (Black) - Workhorse/baby
Fourth car - 1998 Citroen Xantia Exclusive Estate (Red) - Minor project
- barry badger
Thanks Kevin, i will be on the phone to chevronics first thing in the morning. It's the fuel sender unit i'm after, mine is cracked , i've repaired it but would be happier with a replacement.
BigRedAngus wrote: ↑Tue Jan 02, 2018 5:30 pm Hi Kevin. I've tried PMing you, but I don't think it has gone through. Can you check please and message me back if not?
Hello Angus,
I did see your first PM, and replied to you with a contact phone number, so we can discuss in further detail. As I am keen to find a good home for the final car if possible.
Just in case I will send you another PM
1960 Land Rover 88"
1999 Kawasaki ZX9R
Received and replied!
