Hi all, just picked up a non running red 89 16 v, all original. My aim is to get her back on the road but it won't be next week!! Bodywork is pretty fine, just in the process of checking the fuel system(where can I get some reasonably priced used/new fuel pipes?) Then will check over the ign prior to attempting a start up. I reckon she has been laid up in Essex for approx 10 years. Once running I will have a better idea of any forthcoming grief, wish me luck, and some!!!
Regards Mac
New to Forum, Mk1 BX 16V
Re: New to Forum, Mk1 BX 16V
If its been laid up for that long I would highly recommended that you change the cambelt as the old one maybe perished and if it breaks you could end up in a world of pain and potentially a very expensive repair job.
Try Plaeides they can make the fuel lines for you or Chevronics.
- x 150
As Cliff says
CAMBELT first!, don't drive it until then! if it snaps you will need an expensive head rebuild.
Rob Moss at Chevronics keeps fuel pipes in stock I think.
www.chevronics.co.uk
And initially I would slip the belt off the hydraulic pump, this will prevent any fluid loss from perished pipes and put less strain on starting, once you've got it running then slip belt back on and see how the hydraulic system performs, I would imagine the spheres would have gone flat so dont expect your brakes and PAS to perform too well, you will need it to lift up if you want get it onto a trailer\trransporter.
- My Cars: Bx 16v, Riley Elf, Volvo V60 D5, Clio 200 Sport
Re: New to Forum, Mk1c BX 16V
Thanks for the replies, much appreciated. Regards Mac
