Kitch wrote: ↑Wed Dec 19, 2018 2:00 pm
I see your copper, and raise you Kunifer.
A bit overkill for fuel line though. And is it even available in 8mm and 10mm...?
Actually, if I was doing it again and didn't already have some copper in stock, I'd use nylon pipe.
Hardly overkill. It's not much more expensive than copper (like a couple of quid), and doesn't corrode as quickly or work-harden as much. I buy it in 8mm lengths all the time, as we plumb the TVRs out in it.
Ah ok. Only ever seen it before in brake pipe sizes.
