Chris' BX blog
deltic
x 12
Re: Chris' BX blog
Post by deltic »
Unless you're buying a new set try to get a matched pair if used. I've learnt to my cost from buying individually that they fade at different rates.
2006 C4 VTR+ 2.0 Coupé, silver, 68,000 miles
2007 Hyundai Coupé SIII 2.0, sky blue, 53,000 miles
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
2003 Toyota RAV4 2.0 D4D
x 35
Re: Chris' BX blog
Post by white exec »
Will remember that - thanks.
My Cars: LOTS!
x 114
Re: Chris' BX blog
yes they come in dark smoke, light smoke, blue tint, red tint, green tint......again ive made that mistake too!
white exec
x 35
Re: Chris' BX blog
Did a fuel calculation for the car today...
Over last 2774km (1734 mi) — 42.8mpg (6.6 L/100km).
That'll do for starters, and almost all on local urban and 2nd-3rd gear mountain roads.
10mpg better than the D4D. :)
My Cars: LOTS!
x 114
Re: Chris' BX blog
white exec wrote:
Thu Apr 01, 2021 5:45 pm
The bx is a light car and fairly aerodynamic, I get over 40 out my 19GT if driven sensibly, the DTR runs on fresh air it seems
Which is a lot more than a modern Mini Petrol I did have did.
white exec
x 35
Re: Chris' BX blog
The 42.8 is pretty close to the 44 we used to get regularly from our 19RD back in the '90s in the UK. Towing a caravan all over Europe, it still returned 32. It is an extraordinarily good engine, with a lot of lugging power. Looking back (and in comparison to the huge torque available on the 2.5 XM), the NA 1905 BX never let us down when taking the caravan over Alps and Sierras. We did look after it, though, adding a second fan and an expansion tank. Interesting that the '92 Millesime - the RD was '89 - came with twin fans as standard, with essentially the same engine, but maybe because it has A/C.
My Cars: LOTS!
x 114
Re: Chris' BX blog
white exec wrote:
Fri Apr 02, 2021 12:39 pm
yes A/C cars had twin fans.
Amazing what a good service can do for a car, blocked filters and old oil and plugs does affect the running.
white exec
x 35
Re: Chris' BX blog
Some improvements to the original cabin lighting completed now. Found the pillar lights a bit unexciting, and the swivel map-reading light at the front (no sunroof on this one) only candle-power.
Map reading light at the front was simply cleaned up, and fitted with a 36mm warm white festoon LED. Found one that threw all its light in one direction, which was just the job:
LED from the MAXGTRS shop on AliExpress...
https://www.aliexpress.com/item/3297585 ... 4c4dHPuD51
Light in the driver's or passenger's lap is now transformed.
A new front overhead light
The original door pillar lights were never very good at providing general front seat lighting, and so one of these was fitted:
Still current PSA part number is 6362K9, and that can be found through google, and available as an aftermarket replacement from dozens of sources, including Amazon. It was fitted to many Cit/Peu vehicles.
Convenient 3-way switching. I wired it into the system at one of the pillar lights. Retained the W5W capless tungsten bulb. Space for it was the now-disused I.R. central locking module, which was simply unplugged and removed. The new fitting was inserted into the finisher cover.
Pillar lights
The pillar lights were simply fitted with some 36mm warm white festoons. These did the job, and were nicely brighter (and less yellow) than the original 7W tungstens:
https://www.aliexpress.com/item/3257368 ... 4c4dHPuD51
The same festoon LED has been put into the boot and glove compartment fittings.
Lastly, for the rear seat, a pair of over-door light fittings were added:
These were acquired ex-XM/605, and came complete with the original grab-handles they were fitted into. I had toyed with the idea of fitting the grab-handles too, but they were too large to let into the headlining and the space behind, and would also have not been in the right place. In the end, I discarded the XM/605 grab-handle surrounds, and just used the clip-in light fittings themselves.
The new fittings have two W5W tungsten bulbs (which were retained) - one for general illumination, the other (with its own switch) for reading. The wiring was again taken to the B-pillar light.
A narrow rectangular cut-out was made in the headlining, and in part of the steel strip behind.
Lastly, the original pillar lights were disconnected from the 'doors open' ground line, so that they no longer come on automatically when a door is opened, but can still be switched on by the original switch. When doors do open, the new front overhead light and the new rear seat lights come on instead, operated from the same timer-ground connection at the pillar lights.
A switch was added to the central console (near the handbrake), so that the interior lights could be turned on without opening a door, and also shut off (cabin lights killed) for working on the car with doors open.
RobC
My Cars: 1991 Citroen BX 16v
x 16
Re: Chris' BX blog
Post by RobC »
Nice work! 😎
