Ive got a TZD today
- Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Where-aboutsBarnsley BXer wrote: Aye, good point mate. It does help a bit though as I have a couple of good `rally slagging` lanes I can use on way/way home from work which are magic when wet and even better when snowy.
Tel.
- docchevron
A GTi speedo will be wildly inaccurate in a TD. The gearing is higher in the TD so a GTi clock would read low....cavmad wrote:I`ve got a set of GTI clocks mate, though Ian Fearn has first dibs on the temp guage.
Chris G
I reckon postage will be about £8.00 Ian. Iirc Mulley isn`t too far from you, if I send the whole lot could you two meet up and take what you want for them?
Mulley, somewhere about I`m pretty sure I have some standard TGD (i.e non turbo) clocks, if you or anyone else knows if the speedo will suit your TZD please let me know.
Ian, if you pm me your address and postcode I`ll send the clocks out to you mate, most likely Saturday morning if that`s o.k?
Vauxhall apologist.
Terry Brooks wrote:Where-aboutsBarnsley BXer wrote: Aye, good point mate. It does help a bit though as I have a couple of good `rally slagging` lanes I can use on way/way home from work which are magic when wet and even better when snowy...........are they local to me
Tel.
Between Ellesmere Port and Chester mate, there`s one corner which is usually covered in gravel and when you hit it just right you can slide it perfectly around the bend.
Get it wrong (i.e with a Cortina automatic in the frost) and it`s a trouser-browningly experience
Vauxhall apologist.
- Ian_Fearn
PM sent mate.cavmad wrote:I reckon postage will be about £8.00 Ian. Iirc Mulley isn`t too far from you, if I send the whole lot could you two meet up and take what you want for them?
Cheers.
Over and out from me
- docchevron
Fraid not mate. a N/A clock would read low. It would have to be a TD clock to be accurate. A N/A clock would be 10mph out unless you change the profile of the tyres.
Chris G
Chris G
tim leech
