Special 25th Anniversary Flyer
- Philip Chidlow
- x 25
For anyone who wants to flyer BXs!
Four will fit on an A4 sheet (portrait format)*.
*Like this:
*Like this:
- stuart_hedges
- stuart_hedges
- docchevron
- stuart_hedges
No pressure then ! No, this is exactly what I needed otherwise I would have never got the thing done! Anyone know of anywhere that steam cleans engines in the Midlands? I need to find the oil leak this weekend. Its no good as it is. It started to get stupidly leaky towards the end. Im more worried about this that fixing the accident damage. Ive replace three main oil seals. Both crankshaft ones and the right camshaft one. I cant remember why the distributor side never got done, but its really coming out quickly around this area, so its either that oil seal, the rocker cover seal, or, worse, the head gasket. Cant see what else it could be. The distributor is certainly covered in oil.classic2cv wrote:one more Mk1 back on the road soonstuart_hedges wrote:Adam, you're a hero. Good luck and see you soon!
I know you are going to be sceptical but are you sure it's not the dipstick? I had this problem by that area and it is because of a progressive break up of the "stopper" part of the dipstick orange handle allowing the dipstick tube to act as a breather. New dipstick £4-70 from GSF - Problem Sorted!adamskibx wrote:[ I cant remember why the distributor side never got done, but its really coming out quickly around this area, so its either that oil seal, the rocker cover seal, or, worse, the head gasket. Cant see what else it could be. The distributor is certainly covered in oil.
