Doseur : that sinking feeling ?
Just had a look on Citroen service net to re-assure availability of the most vital parts for overhauling the Brake doseur valve.
Parts are valid for BX/CX/XM/Xantia doseur valves all models all valve styles.
2 - 5.424.455 DOSEUR RING 27X32-7 (locator ring for rubber knob)
3 - 95.640.067 RUBBER PROTECTOR (rubber knob)
11 - 79.03.065.983 (*NFP) O-RING DIAM 40X43,2X1,6 (end cap seal) early BX/CX 2piston style
11 - 95.638.813 O-RING TOR 42 T1,6 (end cap seal) later 3piston style
12 - 95.495.759 DOSEUR SEAL 14,7X14,9-2 (tephlone seal)
13 - 79.03.065.984 O-RING 16,4X19-1,3 (compressor O-ring)
*NFP : no longer available, but may still be stocked at some dealers.
The material is mineral oil tolerant Viton rubber.
Sorry Markmnde wrote:Just to clarify (and get them both in the same post ),
The large O-ring (No. 11) is 42mm dia, round section, 1.6mm thickness
The small O-ring (No. 13) is 16.4mmx19 dia, square section, 1.3mm thickness
Cheers,
Mark.
But "The small O-ring (No. 13) is 16.4mmx19 dia, square section, 1.3mm" is not a square section, its a round section.
This is to make it as flexible as possible as its used for compressing the tephlone ring round the piston.
- mnde
- Meteor Man
OK great thanks for clearing that up; it was just that No. 13 looked square section in the exploded diagram.AndersDK wrote:But "The small O-ring (No. 13) is 16.4mmx19 dia, square section, 1.3mm" is not a square section, its a round section.
BTW, what does the "x19" bit mean?
Thanks,
Mark.
So in the end, the only part which is really hard to find would be...
...right?
For the 3 piston / 1988< type, all seals should be available somewhere through normal channels? I'll ask around in Germany and France when I get the Chance. Where did you get that availability info from? If it's the same service net the Swiss citroen branch is using, it would be odd that they told me it's not available anymore, as I was calling the head office. Maybe it was a misunderstanding.
Thanks for all the infos, Anders!
...right?
Carl
1989 16 Valve
Parts needed:
- One black leather headrest.
1989 16 Valve
Parts needed:
- cauchoiskev
At the risk of repeating myself, and for anyone who hasn't read the whole thread, I know for a fact this has happened to myself and somebody else here in France :
"However, a word of warning to anybody attempting this job : I have bought two o-rings since doing my doseur (part n° 79 03 065 984), and they were both the wrong size (too small).
These parts come from the factory, so there is a fair chance it could also happen to anybody else, so verify before opening/taking off your doseur.
The correct size is 16.4x19-1.3."
- kermit the frog
Hi
I have this problem on my estate but have just scrapped my old hatch and have removed the doseur valve from that so will overhaul that.
Also near to where i live is acompany that make viton seals so i will attempt to take the sizes to them to see if they are a standard type.
If i am lucky i will find out the part numbers for their seals and post them on here.
Regards Kermit
Regards Kermit
- x 4
Only just got round to reading this thread and wish I had earlier... my TZD Break tends to drop quickly at the rear, so maybe there's a doseur problem, although it's less apparent since I gave the system a good workout the other day, moving it from high to low repeatedly and working the steering through its full range.
I've got a spare doseur on the spares car, so I think I'll look into getting some new seals, rebuilding that and maybe changng the doseur at the same time as the heater valve, since both involve some delving down behind the engine. Would definitely be interested to know if seals are available from another source.
- x 4
But they weigh nothing - surely some dealer would post them to you...?
- x 4
I'm sure with the miracle of Paypal someone on here would buy two sets when they're doing their unit and send you the second set. If non one's done so by the time I get round to doing mine, I'm happy to do that (but you may have to wait a while!).
