DavidRutherford wrote:Or even just a typo, with O and I being adjacent to each other on the keyboard?
Indeed!
On running non-diesel products in a diesel, it is actually perhaps a rather more complicated equation than I inferred.
The Xantia I had, I ran on 100% WVO, or with 10% petrol when ambient temperatures were cold. The car always started, and although a little stumbly when cold, ran very well when warmed up. Accepted wisdom suggests that cold running can be improved by either a touch more advance, or altering the outlet banjo on the pump for one with a different sized hole.
When I scrapped the Xant, I kept the pump and injectors, intending to fit them to the engine I fit to my BX. Issues I have with doing this are as follows.
1) Having removed the Xantia (Bosch) pump, I found that the driveshaft seal is leaking. This could be down to age as much as the use of WVO, and I have manged to buy a new seal set for about 7 quid. The chances of me sucessfully replacing the pump seals are pretty good (particularly with Citrojim having an excellent online tutorial) however I feel that seals will always be on borrowed time when using high concentrations of veg.
2) Hassle. Filling up out of cans is time consuming and messy. Even if you're careful splashes end up on your coachwork, and make for a sticky and horrible build up on the side of your car which are difficult to remove. Stopping at a filling station is rather more convenient...
3) Longevity. Diesel cars can run on all sorts of shite, but they are designed to run on *Diesel*. By running high concentrations of veg, there is a risk of breakdown and excess wear due to unburnt deposits that otherwise just isn't there, And, even the mighty Bosch VE will only put up with 100% WVO for so long. There is the ever-present risk of blockages too.
4) Smell. Despite what people would have you believe, burning veg (at least WVO) does not give a pleasing odour. The smell is a sickly sweet and somewhat rank one, which makes me feel sick when driving in traffic with the roof/window open.
This said, should you have an old beater that you're not particularly arsed about, and don't mind dealing with mess, smell and the odd blockage, I'd say go for it. However, I strongly suspect that when I get my BX back on the road, I shall be fueling it exclusively with DIESEL!
