Much loved BX RD Turbo - good home wanted
x 150
I think its all done to setting the pump timing and doing something with the head?
Contact:
Erm, I've done a fair few things to it over the years, some were sucessful, some were, er, catastrophically unsucessful.
Running 150BHP is possible, for about 300 hundred miles, then the head explodes.
At the moment the engine is running a Garrett T3 twin vane turbo, has triple angle bigger valves, a camshaft from an N/A, runs 1.5BAR boost, the boost fuelling has been increased a touch, straight through exhaust with a Scorpion free flow back box.
Aside from the fact it seems to keep blowing oil seals it does seem to run it reliably, but it was a rebuilt engine when I started tinkering with it, I then rebuilt it again when I trashed it in 300 miles, then I rebuilt it again when it went bang 3000 miles later, then I turned it all down a bit!
I actually came to the conclusion that it was pointless trying to get valver speed from a diesel, if I want speed, I have the valver.
That said a slightly tweaed TD is still an impressive car in it's own way.
Although as was the point with diesels really, it's the torque I use more than the power. Torque is great!
maxgreenwood
Post by maxgreenwood »
Torque is great!
...and cheap it seems
'90 16TZS (m), White, 86k
maxgreenwood
as in good fuel economy
