Jackson's TZD
jacksun1987 wrote:What modles have the same spioler that i have got?
Thanks
Hurricane and Phase 2 valvers only.
Hurricane
Post by Hurricane »
Thanks for the pictures, it's unique allright, I like Black ones. :D
K BX 19 TXD
J BX TZD Turbo Hurricane
J BX TZD Turbo
jacksun1987
Post by jacksun1987 »
Yes i think i have got a older percel shelf. It has the blinds in. But the pins dont fit the car. The seats are the ones what you lift forward and then you pull the back down. So i do need a later percel shelf. So if any one wants a older percel shelf. In blue I have got one. lol
The car does not have abs. There is no box undernieth the frount seat.
It is a all sorts bx. But its fun trying to find out who or where or what it is. Its a mystery game. Fun Fun Fun lol
PAUL JACKSON
cosa 1.2 brezze 150 k had
Post by RxBX »
Paul,
jacksun1987 wrote:........The seats are the ones what you lift forward and then you pull the back down...........l
They all do that !
If you read and deciphered my post correctly ?
RxBX wrote:.............The later rear seats also had the 40/60 split in addition to being folding and the parcel shelf had a different type of fixing each end of the parcel shelf (radial hook affair) plus the addition of being supported at the back rest part of the seat at the 40/60 centre area ! ...............
So let's try again !
Have your rear seats got the 40/60 split feature in addition to them being folding ?
jacksun1987
Should be the ones where you fold the down all the way.
I understand what you mean. I have the booklet on the bx and the.
BX and Bx 14 e Can not fold down flat as the BX 16RS BX 17RD BX 16TRS BX 19DTR BX 19TRS and the BX19GTI you can fold the all the way down
So im sure you can with mine they should lay flat.
PAUL JACKSON
Matt H
Post by Matt H »
Just one thing... please be careful not to smash up that rear bumper... It's from a Phase 2 16v :shock:
jacksun1987
ill try not to. Could always do a swap for a black tzd one. But mine would be a bit differnt. If we all meet up.
Whats the visabilty like one the baby walker ones. When you look out the back. It would do my head in a bit. Lokking at one parking up.
PAUL JACKSON
Post by RxBX »
Paul,
Your damn hard work young man !
jacksun1987 wrote:Should be the ones where you fold the down all the way.............
You still have not stated/confirmed if your BX has just the folding bench rear seat's or it has the later type ones with the 40/60 split as-well !
So for the third and final time I'll put it in very simple terms to you so that you can hopefully identify which type you have !
Does the rear base seat fold up all in one piece (i.e. both Left and Right hand-sides simultaneously)
or is the base in two pieces, Left hand and Right hand side (i.e. split 40/60) are separate ?
If you find it difficult to work this out and to report back with a valid answer maybe a Photo will be the only way you'll be able to !
jacksun1987 wrote: I'll try not to. Could always do a swap for a black tzd one. But mine would be a bit different. If we all meet up.
Are you after the correct spec. rear bumper in Black for your TZD ?
As I have one available, PM me for more details if interested.
1985 CITROEN BX 19GT C1TBX
2003 Rover 25 1.6i XL L33CHT
x 92
Richard dont burst a blood vessell, leave him to it. If its a H plate it should have the split fold rear seat, from the photos it does have the correct front seats so if the rear match it should have a split foling rear one, as for the rear bumper and spoiler, I would leave them alone as they match the colour ok, maybe get a black valver front bumper to match sometime?
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
jacksun1987
No it is not the bench type one. They are sperate. You pull the seat up right is just the right side. While the left side does the middle and the leaft.
They fold flat down.
Emm not sure about the spoiler. If i want to keep it orangnal. Then it has to go. But just got the car. See how i feel later on.
PAUL JACKSON
jacksun1987
I could turn it in to a 16 vavle look alike.
PAUL JACKSON
Post by RxBX »
Paul
jacksun1987 wrote:No it is not the bench type one. They are separate. You pull the seat up right is just the right side. While the left side does the middle and the left.........
=D> =D> =D> We finally got the answer, let's hope it's NOT going to be like this each time you need help/advice !
Right, so back to the reason for the above info you've now kindly provided, so as to establish which type of correct parcel shelf your needing/looking for ?
As by your previous posts in this thread you stated that your 'Bertie Bassett' TZD has the wrong colour parcel shelf and end connections at the pivot/fixing point, correct ?
a) I take it that the infill panel parcel shelf side supports just inside the 'C' pillar (Both sides) are in Black Yes or No ?
b) If YES then you need a replacement in Black to match !
c) Being a TZD preferably with the pull up blind's but you could always transfer them over if the current one's are in good working order.
d) The parcel shelf need's to be the later type to be compatible with the 40/60 split design configuration (i.e. with the radial/hook at the pivot/fixing point).
Paul !
Have you now deciphered all the above in a,b,c & d ?
If it's YES to all four item's do you want me to see I have a decent replacement to suit your need's ?
Oh, and BTW have you contacted 'Medway Citroen Garage' over all your concerns with 'Bertie' yet and if so, what are they proposing/prepared as to rectifying the faulty items for you ?
Regards
jacksun1987
Cant be bortherd with medway. Ive got the car now. So im doing it my self.
The percal shelf does not fit. Its a dark blue one with blinds. Seems to be a older one. I can not get it in the slots. Keeps falling off. Would be very intrested in doing a deal. Boot plus percal shelv. With me giving a bit of money. If you want to?
I know the boot looks good one it. But at the end of the day Orangnal is better then bits and bobs.
If im being really picky the passenger door window does not match. Its a brownish coulor. I think that was a older modle tint. Or a basic modle.
Thats all i need to do on the looks department. One the car just electrical stuff. Then after that should be a good car.
PAUL JACKSON
jacksun1987
Yes on the persal shelve there is nothing on it to slot in any where. But it has the blinds. I know for the fact it does not belong to the car.
PAUL JACKSON
blackbx16v
Post by blackbx16v »
Thanks
and Pallas and Ourane
1989 BX 16valve mk2
1993 BX Break 4WD
