HP Pump
scarecrow wrote:Bob, I'm probably just stating the obvious here, but couldn't it be that the problem wasn't the pump after all, as you'd tried two recons?
Steve
Nahhh. I was beginning to think that too. But (1) swapping my original pump back in instantly cures the fault(s) and (2) the recon pumps display different faults (one pump clatters like a bag of spanners and the steering's totally unpowered, the second has a pronounced 'tick' and the steering cuts in and out until 1500rpm)
Of course, I could just be a total numpty, with the mechnical abilities of a menopausal chimp on ecstasy and the IQ of an autistic turnip ............
I have one from XM V6 in my car, but don't know how much effort was required to fit it - previous owner did it...scarecrow wrote:I was just thinking - couldn't a Xantia pump be modified to fit a BX? I don't know how different the mountings, and more importantly the ratings of one would be, but maybe this is a possibility...
1993 BX GTi 16V Auto
1993 subaru legacy turbo
- Aerodynamica
I got a brand new pump for my BX last year from Mark Dunsmore at the Cit dealer near Lincoln (or some such) that had a list price of £12ty-million but he made it available for the same price as a recon one i.e. £150+ post.Roverman wrote:Hi Richard
Does Malcolm lockwood still stock them do you know?
Thanks.
£1200! HAHAHAHAH!
I thought he had 2 of them and a brand new FDV too - there was rather a long list.
I should say that it didn't really improve the car much as I think the BX's steering woes occur as a result of worn pump AND out of kilter FDV and filters etc.
Still, worth a go tho
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
- jonathan_dyane
FWIW Mark doesn't work for Citroen anymore.
The Xantia pump may be an option, although 'anti sink' cars (approx '94 onwards) had a 6+2 pump, which did away with the FDV. Will work if you bin the FDV and repipe to suit, but car will take an age to rise, as only two pistons provide suspension pressure (part of the reason for anti-sink).
- cauchoiskev
One person claims to have done it : the mad Frenchman . You apparently need to make a special extractor tool to get the pulley off.Brian wrote:
it seems that no one (Unless someone knows different) has dismantled a BX pump without damaging.
The casing is not heat-shrunk, it is only held on tightly by an o-ring. Once the pulley is off, just grab the casting with the pipe orifices in a vice and whack the main axle and the casing comes off.
There are only two joints and a bearing to replace. The mad frenchman just flips over the worn valve discs. I suppose they could also be machined.
- Aerodynamica
That's pretty interesting! do you know how these disks wear? I thought they were thin disks - I'd be keen to learn of the wear properties. Also, surely the 'seat' in which each disk snaps back onto would also show some wear?cauchoiskev wrote:One person claims to have done it : the mad Frenchman . You apparently need to make a special extractor tool to get the pulley off.Brian wrote:
I was wondering also if there was a difference in the dismantling procedure between the green, steel-cased pump and the later, black plastic-cased item.
If anyone happens to know.
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
- jonathan_dyane
- cauchoiskev
Yeah, that was my line of thought as well, but the mad Frenchman makes no mention of this. I think his main reason for opening the pump was to fix leaks rather than poor performance. Looking at the Citroën drawing, the seat seems strangely to be quite sharp, rather than a flat surface.Aerodynamica wrote: Also, surely the 'seat' in which each disk snaps back onto would also show some wear?
As Jonathan dyane says, I would tend to avoid plastic-cased pumps for refurbishing purposes.Aerodynamica wrote: I was wondering also if there was a difference in the dismantling procedure between the green, steel-cased pump and the later, black plastic-cased item.
Looking at my old pump, this seems to be the groove which you have to grab to get the pulley off :
The two recon pumps I've got here both have plastic end chambers, so presumably there's a way of reliably getting 'em off with out having an "Oh f**k-it! " moment.
I'm surprised the only thing keeping the pulley on the pump shaft is an interference fit ........ given the resistance to movement when the thing's at maxi chat. Is there no keyway?
- jonathan_dyane
- citro-geoff
- My Cars: Xantia VSX Estate-146K-1996 (The wifes car)
BX TZD Turbo-317K- Awaiting repair/donor car(broken subframe)
BX TZD Turbo-202K-project car ongoing
BX TZD Turbo-212k-One owner car rescued from being scrapped.
2CV Charleston-101K-One owner car awaiting restoration.
ZX Memphis-185K-Wifes daily driver.
Pump recon
Hi Tim,have you tried Chris Jacobs of ex CGS.I know he is still doing the pumps from home now,as I have had one done recently for a V6 Xantia,and he used to supply some of the traders when he had the garage and hydraulics repair business.Unfortunately he had to give it up as a business,but still dabbles a bit.If you want his number ring me on 07980 559814. At least his pumps work 100% when they are done!!
1995 ZX Memphis TD Saloon 176k
1997 XANTIA VSX ESTATE-112K(the Wife's!!)
1993 BX TZD Turbo Estate 202k waiting repairs for mot.(Just started to fix it!!)
1985 2CV 100k - waiting full restoration.
- MULLEY
citro-geoff, how much Chris charge for a bx diesel pump?
