Mike E (uk) wrote:These ECUs are normally very reliable.
Welding the car without unplugging them can do damage though.
Did the auto electrician say why he thaught it was the ECU?
A weak spark suggests an HT fault or ignition amp failure.
You have changed:
coil packs, crank sensors and ignition amps.
Could it be faulty wiring/dodgy connections,
King HT lead, faulty distributor cap/rotor arm/fouled sparkplugs?
It is a pain, but try to check all the connections between the ECU,ignition amp and sensors. Use an ohmeter for this.
Don't assume a replacement part is working, especially if it is 2nd hand, unless it swaps OK with a working car. Keep the battery well charged between tests.
Get a helper to try and start the engine wilst you look under the bonnet in the dark-you may be able to see where the spark energy is leaking to chassis.
bon chance,
Mike
Basically, the 'Bosch approved' auto electrician apparently (I wasn't actually there due to being in Essen) tested everything and found that all the signals were getting to the ECU, but nothing was coming out. He then tested the ECU with diagnostic equipment which confirmed it... But to be honest, I'm not going to take any of this for definite, because I wasn't there at the time, and this is quite an old Bosch system, it wouldn't surprise me if the guy had never seen a Motronic 4.1 box before.
Testing directly from the coil now, it sparks once, and then nothing. This is the same on both ECUs and coils, but the when the old ignition amp is fitted, I get no spark at all. My mechanic assures me that this isn't the problem, but the replacement part isn't Bosch (Lucas I think), so I'm not going to rule it out until my Bosch part arrives.
This car was running absolutely flawlessly up to the point it decided not to start. New Magnecor leads about 6 months ago, new plugs, new cap, new rotor arm, new... well you get the picture.
I'm totally gutted that this has happened, and will be getting it home soon to actually have a proper go at sorting it myself... Which is what I would have done in the first place, if my Dad hadn't decided to kill it outside a very competent mechanic's place... who isn't afraid to work on old cars or Citroens.
If I can't get it going again soon though I'm going to have to buy another car, because it is really starting to interfere with work.
I can handle a BX that pisses LHM everwhere... because at least you know how to fix it, but when it won't even run... what am I supposed to do?
I'll let you know how I get on.
Thanks,
Matt
