Gibbo2286 wrote:If you lever out the dimmer switch you may find the wires pulled off the connectors at the back, I've had a few like that. Gibbo.
nice one - that's definitely worth a go
The strutt probably just wants lubing, lift the rubber gaiter then clean and lube the rod or lift the bonnet and just squirt a bit of LHM (using an oil can) into the strut top side access hole then do a few up & downssarahjaneking wrote:
since droplink replaced front n/s seems to get stuck and judder when going into the high position - how do i check it is ok?
