how do i remove the front indicator lamps please?
rmattila
Contact:
Post by rmattila »
mat_fenwick wrote:The plastic headlight mounting sockets get brittle with cold weather (and age) so warm water over them helps if you are taking the lights out in winter.
..or just let the car idle for a while with the headlights on and bonnet closed.
-Riku
x 19
Not with UK fuel prices! :lol: Although the heat from the engine would help to keep you warm...
Post by kiwi »
mat_fenwick wrote:Not with UK fuel prices! :lol: Although the heat from the engine would help to keep you warm...
I think that would be fuel prices in general on a global scale!
johnbird
Post by johnbird »
took the headlights out without too much trouble today.used a length of bar to push as i pulled.worked ok.
the lenses were awful in the indicators so they had the bathroom cleaner and hot water treatment with her majestys best pots long handle brush thing. took about an hour to get them reasonable.they will never be perfect though. i had to find a couple of rubber bungs and selected a suitable drill bit to make a hole in the base of each one in order to get the aforementioned bathroom chemicals and warm water into them. once rinsed i had them in front of the fan heater which is attempting to keep my shed warm enough to spray paint some engine bay brackets and the coil.
i copperslip greased the push on sockets before reassembly to ease the job for the next chap to remove the lights.
had to get some emery and wd40 into one of the bulb fittings to clean the contact and return normal service.pleasd with the result for not too much effort and hardly any cost-until she finds out i used the pot brush!
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
x 151
if you break the bolt John dont worry then indicators are cheap, and once changed they brighten up the front end.
johnbird
Post by johnbird »
could you define cheap please? they are better but im not really happy with them.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
Post by kiwi »
Cheap as in cheaper than a Macdonalds family meal :lol:
11.50 at GSF from what I can see http://secure.gsfcarparts.com/shop/results.asp
Linegeist
Post by Linegeist »
kiwi wrote:Cheap as in cheaper than a Macdonalds family meal :lol:
Online Shop - Search Results
Search Error!
The following search criteria form fields were blank :
Vehicle Model
Product Category or Keywords
Please return to the Search by clicking here.
:shock: :shock: :shock: :wink:
johnbird
Post by johnbird »
if you click on the left menu on the site you can access it ok.they are 11.50 from memory.i have bookmarked the site.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
rmattila
Contact:
Post by rmattila »
Just for completeness' sake, there's a couple of pics on re-installation of the headlights (in -25 deg C for no other reason than just for the heck of it):
"First engage the outer corner socket by sliding sideways."
"Then press the headlight backwards to engage the two ball/socket joints in the inner corner"
-Riku
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
Post by kiwi »
johnbird wrote:if you click on the left menu on the site you can access it ok.they are 11.50 from memory.i have bookmarked the site.
No need for memory I put the price in the post earlier :lol:
Great idea about drilling the hole to be able to get into the lens better so that the crap can be cleaned out. What did you use to clean them out with? perhaps you can use baking soda or something similar to really clean them out? It's a shame that the indicator doesnt actually come apart, but they appear to be glued together, so i think trying to get them apart would only break them, i think your solution is probably the best.
When you say you aren't happy with them, is it because the silver lining inside has degraded? If so, then i guess replacements are the way to go, just watch out for the cheap one's which don't have silver sides, just plain grey, they look crap.
johnbird
Post by johnbird »
the lense still have some algae in the join between the case and lense and there is some degrading of the silver inside. i used toilet cleaner-has anti limescale and bleach in it.and lots of warm water with her majestys best pots plastic brush.the hole was the only way to access the lense body so hole it is,rubber bungs were from the bits box! john.
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
x 151
Ebay is the best place to get them, I have a new genuine citroen one in box I can sell you if you like?
johnbird
Post by johnbird »
Thanks for the offer. I my come back to you. Is it a grey or black body? I will look on ebay too. I only bought the car as winter transport to work I'm not supposed to be spending money on it! It annoys me that they are not matching and still have some algae in them. Ocd I guess!
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
