WANTED: Remote locking receiver & plip
My Cars: BX GTi, C3 Auto
x 83
I have got some that I can check out and let you have one when I am back in the country, probably in May.
Give me a pm reminder after May 1st if no-one else comes up with the goods before then.
BXing into oblivion.......................
maxgreenwood
Post by maxgreenwood »
I'd also like to get a remote plip working with my car. I'm not fussy what badge it has on it. Again.. if anyone has anything, i'll happily exchange for a few notes. It looks like a new PCB board could just plug into the existing socket.
'90 16TZS (m), White, 86k
rayfenwick
Contact:
Post by rayfenwick »
Hi Jaba
That'd be good - all I have to do now is remember to remind you ... :oops:
I have a receiver, but no plip to go with it. If anyone knows how to reprogram the receiver (usually some key in/turn ignition/sacrifice a chicken type malarkey then a plip by itself would be fine... :)
Ray
www.citroencarclub.co.uk
mountainmanUK
Post by mountainmanUK »
http://www.ehow.com/how_7515712_program ... y-fob.html
It doesn't specifically mention the BX (or early plips), but may be worth a try?
Regards
Dave
x 19
With the BX plip, it involves either drilling through tracks on the board to break them, or remaking factory drilled tracks with a blob of solder. I've not had to do it myself, but read an online guide a while back.
I'm after just the plip casing for mine if someone should stumble upon a vast hoard of them!
citroen7
Post by citroen7 »
if you take the serial number of the board to your local cit dealer they can order one for you pre programmed it was not cheap and i was told it would be several weeks,they rang me 4 days later to say it was ready!
rayfenwick
Contact:
Thanks for the info guys - I'll keep at it.
Ray
x 19
Linkfor recoding if required...
rayfenwick
Contact:
Thanks Mat :)
Ray
