Summer 2002 - Bought a 1.9TD Xantia engine directly out of the car, from a dodgy geezer in Anglesey! My god how i was ripped off, £600 for the engine with 60k on it, then the guy wanted to charge me for the box!
November 2003 - Bought Jaz! BX 16v J-reg off Ebay for £360. As half the engine was int he boot and the other half in the bay i could see it was rather buggered and having not had an engine apart myself before i flogged the engine and loom for £200. Leaving me with a BX16v in pretty good condition, with leather and HUGE alloy wheels! Oh and a big hole!
March 2004 - Swapped the 1.9td engine out of the 19rd and stuck it in the BX16v. At that time the timing belt was done, but my 'assistant' right royally fucked it up, timing wasnt close, and a valve hit a piston and that was that! Eventually managed to get it fixed though was told i only need replace the valve. Total conversion time was around 8 weeks as same said assistant sent a CV all over the garage floor, and corrosion around the hub seriously slowed the project down!
June 2004 - went to the states and laid the car up while i was gone. The trip also clocked up some serious bills!
December 2004 - seriously ran out of money to keep the car one the road, couldn't afford the insurance nor tax so pulled her off the road!
February 2005 - got the car back on the road and took the to Southhampton, came back on a trailer! Alternator had failed, but the engine was not healthy! Laid up until after exams!
April 2005 - Oh how the tradgedy continues. Decided the engine needed serious help and was offered many offers of help, and an engine was kindly brought up for fitting!
I was told this engine was near perfect, and while having a large number of miles was very healthy and well looked after! The engine was fitted and paid for and i eventually got it through an MOT.
Then within the first few weeks of June a water pipe blew off, pipe was fixed but the engine was past best and the head gasket had blown! Getting the car through it's MOT had cost me EVERY penny i had, very literally! Fortunately a very good friend bailed me out, gave me the money needed and even helped me carry out a very good engine job!
When we got the head off we found the engine had a brand new head and had at sometime in the fairly recent past, snapped a cambelt. Lots of valve marks on the piston heads and corosion all over the bottom of the block! Basically i had once again been screwed over with and engine that was not in good condition and had not been looked after, with major corrosion on and in the bottom end!
Basically for the last few weeks i've had serious problems with coolant loss and some difficulty keep thw engine temp under 100degrees! My suspicion was that the rad was leaking water through the rad cap. Went to the scrappy yesterday and got a replacement rad along with some very clever electronics to control the fans! However having fitted them and refilled the system, bubbles where continously forming in the water! Once i put the cap on the header tank the pressure has built up to such an extent that the lower block has totally failed. Water is coming through the gasket and more alarmingly through a very porous block!
This means the engine is basically a write off. With no money to replace it, and having spent in excess of £250 on this fucked up engine i am no longer able to continue driving!
I am not happy!
I't looks like i wont be able to help people fixing there cars, and showing the generousity that others have shown me! I'm totally gutted!
Now let me make a few things clear, i simply CAN NOT afford to fix the car, i dont have a penny! Offers of engines and parts, while im greatful for the care and consideration, wont resolve the problem as i can't even afford the oil to go in, let alone head bolts, gaskets etc!
I am simply stopping driving for the forseeable future and will do my damndest not to go near a car for as long as i can manage!
