Mk1 BX 19RD Estate RHD! A new home
Grenman wrote: Replaced it and she is a different motor, goes like a train now.
Would that be like the new high speed Euro link or the Flying Scotsman with a huge trail of smoke????? :lol:
Post by Mothman »
Chuff chuff chuff, making me laugh now. :lol:
New filter primer tops are only a few quid from Beals, they're very good for heater plugs, relays etc. too.
http://www.beal.org.uk/automotive/diese ... at_95.html
Post by Mothman »
Defender110 wrote:New filter primer tops are only a few quid from Beals, they're very good for heater plugs, relays etc. too.
Yes, they are cheap but they are not the same as originally fitted to a MK 1 and you will have to change the ends of the fuel pipes, both in and out to make it work. The original ones have a much larger input and output than what they have in stock. I know, ive tried them.
Grenman wrote: Yes, they are cheap but they are not the same as originally fitted to a MK 1 and you will have to change the ends of the fuel pipes, both in and out to make it work. The original ones have a much larger input and output than what they have in stock. I know, ive tried them.
Yes I've just looked at Matts picture they are much bigger pipes than the MK2 they are proper beefy which is a little suprising as these universal Lucas and Bosch filter tops are very common on much bigger engines than this application. They are a straight swap for the MK2 though IIRC
Not sure if the Mk1's are the same, but a problem I had with the RD I had years ago was a pinhole in the fuel pipe that ran across the exhaust manifold. At first it would lose power when I floored it, but it gradually got worse until it could barely pull itself along. After trying various things I took it to Tony Weston who bypassed this bit of pipe with some fuel hose and the problem vanished.
Another trip up to sunny Snowdonia (no, really!) allowed Mat and myself (ok, mainly Mat) to sort out some of the BX's suspension issues. I knew at least one suspension arm bush was knackered, others looked ropey and the strut tops were suspect. I wasn't wrong...
Not a bad spot eh?
A bush should not look like this...
Car now (unsurprisingly!) feels much tighter at the front end. Also changed the hydraulic pump in a bid to cure the low tick time. Failed. Guess the pressure regulator (as predicted by someone on here) is the issue then. Couldn't get the pump to run once fitted. Wobbling steering didn't work, nor did moving height lever. Might be co-incidence but a stab on the brake pedal seemed to work.
Still A LOT to do on this car and cashflow is an issue. Starting to wonder whether I may have to move this car on for further salvation. :cry:
Oh well. At least it drives better now.
Post by Mothman »
Dont sell her bud, keep persevering, otherwise i know you will regret it.
Well, after a few dark thoughts, I've gone and booked her in for the first stage of welding work. This'll tackle the tailgate hinge and the gaping hole in the rear floor. Depending on how things go, it might result in some improvement to the battered LH rear wing, but that really does depend on a fair wind as my budget is tiny.
At least this work should make her usable. At the moment, I have an estate with a knackered tailgate that's about as practical as a two seater sports car!
x 21
Stinkwheel
Post by Stinkwheel »
mat_fenwick wrote:Image
+1
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 174
keep the faith, it will be so worth it in the end.
Ive reached a bit of a brick wall with my motors at the moment too
Yes, don't give up Ian - you'll get there and when you do it'll be worth it. I now find it incredible that I spent all my free time last freezing winter lying under my RD fiddling with it but I'm glad that I did as it's doing sterling service now.
I've had it for over five years now and I repeatedly lost faith - especially in the colder months - but along the way I learnt a lot of stuff like welding and metal fabrication ( sort of). If you have a Mk.1 estate you are legally obliged to keep it in fine fettle and bring it back to glory! :D
Nice weather in the Fenwick corner too! 8)
KEEP it in fine fettle?! I've got to get it there first! :wink:
Post by Mothman »
Dollywobbler wrote:KEEP it in fine fettle?! I've got to get it there first! :wink:
Ime sure you will.
