Mk1 BX 19RD Estate RHD! A new home
When temperatures plummet and darkness draws in, there's only one man who shrugs off the cold, dons his head-torch and gets stuck into fixing the worst BX known to man. The name of that man? Mat Fenwick. What a hero!
Mat came along to our little 2CV jaunt in North Wales today, but then came back to mine for a spell of tinkering on the BX shed of dread. I'd warned Mat that at the very least it would be dark by the time we got back, but the ice on the vehicles suggested it was comfortably below zero degrees too. I was all prepared to hug the stove and drink tea, but no. Mat gets down to business!
The main task was to try the regulator ball bearing trick - something neither of us had ever attempted. The BX was driven up on ramps (interesting to do in the dark with the windows iced up!) and after various dismantling, the ball was given a gentle tap. Result? Tick time has gone up considerably (with raised revs), though the pump is still running continuously on tick-over. Conclusion? Pump borked or filters gunged up - this diagnosis also relates to the intermittent power steering.
That was the main task, so I would quite happily have ended it there, but no. I was kept from my tea by Mat's desire to change the wiper motor. Oh, and the remaining two glow plugs. And have you seen how badly this breather pipe fits? Result? Better starting (hopefully) and a wiper that no longer thwacks the bodywork.
Tea time? Er, no. Because now Mat wanted to tackle the tailgate wiring. The bloke who did the welding hadn't the time to connect everything back up again, especially after discovering the joys of French wiring. Mat was up for the challenge. Result? Number plates and central locking work, HRW proved problematic and then frostbite and the need for dinner meant we decide to abort.
Thanks once again Mat. I'll get some pictures up later. Once I've defrosted my camera. And my fingers.
- x 8
I'll nominate Mat for BX Hero for January, well done mate. I can testify to Mat's commitment to getting work done when he gave me a hand a few years ago with my TZD, from memory it was a long day & he'd had to drive all the way from Wales to Chesterfield & then onto the citroen meet further down south that very same day.
- x 16
Inspired by 'Workaholic' Fenwick, I had a go at solving the juddery steering today. Off came the reservoir and despite the freshness of the LHM, I chucked it away and put some new in.
First of all, out came the reservoir. The large filter housing was floating around in there.
Mucky
What really concerned me is that I found something that looked awfully like a bit of latex glove in the high pressure feed pipe. I pulled it out, but wonder if this is related to the sudden onset of iffy steering...
Cleaned everything out, put it back with fresh LHM and eventually, up she rose. Sadly, the steering issues remain and she still won't rise without revs. Pump is looking like the main suspect then!
In other news, she's been misfiring and generally pulling badly. Still seems like a fuel delivery issue to me as if I accelerate, she just seems to run out of breath as the revs rise. Same happens on hills with my foot down and occasionally there's a misfire at speed. Runs very sweetly when on part throttle.
Mucky
- x 8
The filters look pretty grubby to me, was there much muck in the bottom of the lhm tank underneath the white plastic disc?
Is the fuel feed from the tank heated by the exhaust manifold? If so, try bypassing this section with some rubber fuel pipe - it did wonders for the 19RD I owned, but took months to track down. The metal section in question had pinholed, which meant poor starting from cold, and loss of power at high loads because as it sucked air into the system. It wasn't a big problem at first but got progressively worse and worse until it was barely driveable.
Ah, you're not the first person to mention that thinking about it. Shame I forgot when it was light earlier...
A chap on Autoshite mentioned that some XUDs heat the fuel off the water pump? Don't think mine does, as I've replaced the water pump and don't remember anything there. Perhaps it is the exhaust manifold then. That's not sounding fun to get at - any pointers?
It is indeed getting very hard to start, though with lots of misfiring and blue (!) smoke (the neighbours must love me!). New glow plugs have been fitted to all cylinders now, but while it catches immediately, it soon sinks into the bad running.
- x 16
It's a housing round the back of the block, behind the water pump. Gut feeling says air leak into fuel, temporarily replacing fuel hose with clear tubing would prove/disprove that theory.
Regarding the HRW wiring, what I was left with on the LHS was an earth and a live when HRW on wire from the car, and two wire, each going to one side of the element. As the element is not polarity sensitive, I just connected up the live to one side, and the earth to the other.
This resulted in instant blowing of fuses, which is never ideal. So what I think is happening is that one of the wires to the element is linked to earth by one of the other earth connections to the tailgate. I think I've inadvertently connected that wire to the HRW switched live, giving a dead short when you turn it on! Should be easily sorted....
An air leak certainly fits the bill. Not sure how to access that block. Beneath or take the air intake gubbins off?
Don't worry about the HRW. As I said at the time, it's hardly a priority! 2CV doesn't have one at all, and the Mini and Peugeot 309 have entirely non-working ones. I'm used to living with it!
(oh, and greasing the door handle mechanisms means I can actually get into the BX now! Need a hand to get the passenger door open before sorting that one out as well...)
- x 16
