K39
K39
Sadly I have to sell my 1993 BX TXD.
It's a red one that's still red and now in showroom condition.
I've had it since it was 2 years old and passed it down to my son in law 4 years ago.
3 years ago he followed me into Picasso ownership and it's been on sorn ever since.
SInce june I have done a complete refurb. it will be MOT'd next week and taxed for 6 months.
With it will come a comprehensive list of known good spares including things like power rack, front calipers, hyd pump, h/ lights, rear lights, to name a few.
Will add some pics later, they are on BXP already for anyone interested.
It's advertised at a grand locally, but I'm offering 25% off for anyone on here or BXP.
67 and still rockin (but not in a chair)
- x 21
- x 168
Re: K39
As im in the BXC and the CCC does that mean I can get 50% off then Phil?philhod wrote: It's advertised at a grand locally, but I'm offering 25% off for anyone on here or BXP.
Timmy
- Keeper of the site Goat
- x 168
OK list of known working spares to go with car AND ALL included in the price
Power rack with TRE's and ram. Complete clutch assy, release brg and cable weight.
3 Front brake callipers + 1 disc?. N/S Driveshaft complete. Bosch diesel pump and sprocket, 4 injectors, fuel lines, HP Hyraulic pump, Gear selector linkage, Speedo cable with g/box drive, Waterpump, 19/n/a camshaft with sprocket pump drive and oil seals,Camshaft top cover, Late (oval) diesel inlet manifold, Accumulator sphere and 4 mm pipe. Btm steering joint (new),
Alternator, 2 Starter motors, Complete heater unit with behind dash control unit, Rad fan and surround, 2 headlights, 2 rear light units complete (smoked), 2 clear front indicators, Rear wash wipe unit with arm., 2 window lift motors, Sunroof motor, Glow plug relay/ timer unit, Ignition barrel, keys and door locks. Lights, Horn, Flasher, indicator, column switch, Interior O/H lights and switches.
Radiator with 2 top hoses, Front screenwash delivery pipe, Canbelt cover top and btm, Drivers door mirror comp.
Set of valve stem oil seals (new), Bag of assorted Hyd pipe rubbers.(new) 2 front door cards black with red stripe, and lastly 4 early wheel trims.
AND ALL that's included in the price.
- x 168
Fantastically, in 14 years its been great, a rotor arm and a perished fuel pipe in 10000 miles is all thats let go asides the usual service items. It doesnt get used that much these days as I have 6 Citroens and its not exactly cheap to run!.philhod wrote:![]()
Hows your Rover running these days
I've always wanted a SD1 but they've always aluded me. A series one V8 in Mustard with leather would be my ideal one.
For a pristine pale blue 2600 auto. That thing cost me a fortune. Cold start device packed in, it got through 2 compensator valves + gallons of ATF, until I fitted the mod kit no one told me about, rear axle replacement,
Bearing had worn through the casing at one side. Altenator and battery. It was only a bout 4 mpg better also.
The bleeding thing was only 3 years old when I bought it and I kept it for 2 years, till I traded it in for a 6 month old Montego
