I need to do this on mine soon, does anyone know if it's a replaceable filter or is it just a washable gauze type and I assume it's a sumppan removal and not in the end panel?themildbunch wrote:Drained the ATF for some nice pinky pink dextron II.. going to replace that and clean the filters soon..
Citroen BX diesel automatic.
It's all well documented in the official manual... you can still get the pdf on the wayback machine... looks like you'd need it too with all those different length bolts!Defender110 wrote:I need to do this on mine soon, does anyone know if it's a replaceable filter or is it just a washable gauze type and I assume it's a sumppan removal and not in the end panel?themildbunch wrote:Drained the ATF for some nice pinky pink dextron II.. going to replace that and clean the filters soon..
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
GSF accy sphere should be ok, perhaps the one you have is duff or there might be another issue with the hydraulics that is affecting the tick time?? If the lhm is ancient, that might be another causal effect, hopefully hydraflush might help.
