Added Value add-ons
- Tim Leech
- x 148
The front mudflaps are pretty much the same on all models (except 16v) and you can normally adapt them to fit.Grenman wrote:Ok Tim, i thought some one would say this [you] and i probably will as i dont think they will fit the TGD. Going to look at it tomorrow.Roverman wrote:If you have a set then HANG on to them!
More concerned about getting Sophie better though.
- x 88
Don\'t ever let other people\'s opinions piss you off - you won\'t last 5mins in BX ownership!Grenman wrote:Not at all bud,Kitch wrote:Like I said mate, it\'s just my opinion. Don\'t get offended by it!
only get pissed off by those that take the piss and all the comments i have seen from you have been heartfelt and truly worthy of comment.
Keep em coming.
1990(H) 16Valve (Rouge Furio)
[Don't ever let other people's opinions piss you off - you won't last 5mins in BX ownership![/quote]
Had one in the family since 1985, got a thick skin too and this forum is far too valuable to probably the both of us to let such silliness get in the way.
Mind you there's a few snotty antipodeans about [wow what comment that will get?].
Anyway, this is a forum where i hope such problems can be overcome. I am not a real mechanic but if Sophie needs real medical help, ile have her engine out and sorted, hopefully with a lot of help from guys such as yourself.
There were only 3 faults when i got her, a dodgy up/down drivers side window switch, inside tailgate light being loose[bracket broken] and a slightly damaged near side rear view mirror, all replaced from my donor motor.anaconda wrote:Just love seeing fresh pics of cars when people have got stuck into them. Indeed the added on bits are a question of personal pref, but whatever, this looks fantastic.
.....and its white! Kudos
Will be waxoiled all over this winter.
The driver side passenger window switch on mine takes it down but not up, so I need to use the passenger side switch to get it back up. The drivers side window is slow going down, seemingly cos the rubber horizontal window trim folds down and causes friction against the window. Suggestions for repairs welcome!
Funny how these idiosyncracies become kind of ok, cos its a BX.
1991 BX TGD Saloon
1990 VW T25 Camper. Currently on sabbatical
If you need another switch, i have several spares and it could be just that the bit of metal the window winder moves in needs a bit of lubrication, ie a good greese. Did this with my passenger window on the TGD earlier in the year and it worked properly for the first time in 2 years.anaconda wrote:The driver side passenger window switch on mine takes it down but not up, so I need to use the passenger side switch to get it back up. The drivers side window is slow going down, seemingly cos the rubber horizontal window trim folds down and causes friction against the window. Suggestions for repairs welcome!
as Andy say grease the chanles/runners, the other thing i find helps is spray the felt chanles around the glass with silicon spray,
