BX Gearbox
x 168
Bump!
x 21
Patience Tim, it had only dropped to the third post from the top so not in danger of being forgotten about! :wink:
The CCC isn't until May so Jay's box would fit the bill, plenty of time after Christmas to put it in.
x 168
Bump! :lol:
:lol:
patience |?p? sh ?ns|
noun
1 the capacity to accept or tolerate delay, trouble, or suffering without getting angry or upset : you can find bargains if you have the patience to sift through the dross.
2 chiefly British term for solitaire (sense 1).
PHRASES
lose patience (or lose one's patience) become unable to keep one's temper : even Lawrence finally lost patience with him.
ORIGIN Middle English : from Old French, from Latin patientia, from patient- ‘suffering,’ from the verb pati.
:wink: :D
Post by ken newbold »
It's certainly not one of my virtues. :evil:
JayW
x 13
Post by JayW »
It's easily controlled... Just lock the doors to the ward :wink:
Or give them MRSA...
Tim, whats up with the box? I asked a question about it but no one's actually said what the issue is apart from a noisey idler? What does that actually mean?
normally worn noisy bearings on the idler shaft.
That means nowt to me Kevan :lol: So in laymans terms, what does that actually mean when using the gearbox?
x 168
Defender110 wrote:normally worn noisy bearings on the idler shaft.
As Kevan said, the bearings are worn, they may be fine for years to come BUT with the CCC coming up I dont want to take any risks.
I've seen one that failed, not a pretty sight.
Does it mean that its difficult to change gear? or is it what keeps all the bits in the right places, so if that goes ping then its bang?
It will go bang eventually but it's the noise that is enough to make you want to sort it. Gearbox may be good for a while but it won't improve it will only get worse.
Imagine someone hitting your gearbox with a sledge-hammer, from inside!
Result large hole in side of box :(
x 21
On the bright side there should be more gearboxes in France! :lol:
