Mickys blogalog
already done Vanny and the heater is working fine.
In other news the car has now decided its scared of the dark
the last three nights I have taken the kids to clubs between 6.30 and 7.00 pm and all is fine,
gone out to pick them up between 8.30 and 9.30 and it just dosent want to start, in fact it dosen't start at all,
then its fine the following morning.
tonight I turned the key and nothing happened,
turned it again and the car turned over but would not fire.
/\ that's standard procedure on 2CV/Dyane/Ami, and on BX petrol carbs, and AFAIK on most downdraught carbs
R-reg (1976) Ami 8 owners manual
E-reg (1988) BX petrol owners manual
K-reg (1993) BX owners manual
Several things going on there MickMickey taker wrote:In other news the car has now decided its scared of the dark
When it turns over:
- if it's slow turnover then you have a dodgy battery or one of the clamps is loose, which is also the cause of the non turnover issue and poor starting.
- if it's fast turnover then you either have a dodgy ignition-switch, or a dodgy solenoid on the starter motor, causing the non turnover issue.
When it is turning over: if it will not start easily are you following the Citroen destructions in above pics ? If yes and it still won't start easily on fast turnover then you need a carb recon kit and a "round thing".
Dodgy igniton-switch/solenoid check: next time nothing happens, turn the ignition off, then use a screwdriver and hammer as follows.
-use the screwdriver to short the start terminal on the solenoid to the main battery feed . If the solenoid engages but the motor does not turn then see ffff below. If the solenoid engages and the motor turns, then try the ignition-switch again. If nothing happens try screwdriver again, etc, etc. If yes to screwdriver and no to ignition-switch, then it's the latter.
-if the solenoid does not engage when using the screwdriver, tap the solenoid with the hammer. If it engages then it's the solenoid.
If you don't know how to do the screwdriver trick, don't even try it !!!
ffff: it's either the main terminal in the solenoid, or the starter motor itself.
My money is on a solenoid problem: either the solenoid itself, or the main terminals in the solenoid.
You also have a carb problem methinks.
you should have kept the Golf
think Im in for a busy weekend ,its now decided its not just scared of the dark but just dosent want to go out at all, started fine at lunchtime then an hour later spun like a top but wouldent spark, think I might treat it to new distibutor cap , rotor, leads, sort carb out, check all the connections and go from there
last Tuesday I fitted the new ignition module and plugs, the car has been running fine on the mechanical pump, almost instant starting from cold and a few cranks when hot, then friday afternoon after a 16 mile run , it started then died.
Back on the electric pump it fired up and ran fine, smell of petrol was located, the outlet pipe on the electric pump had come loose or maybe it had always been a bit loose but had not noticed it before, tightened it up and the smell has now gone
well touch wood the car has been running fine this week, still hesitates a little coming off of roundabouts but throttle down hard and it pulls through, I still have to sort out the weeping water bleed valve next to the thermostat housing but generally shes running ok.
The cars getting a break next week as we are off to whitstable for a holiday, when I get back im hoping to treat it to a set of good part worn tyres I have found already on BX rims and the splitter I am collecting from Bill.
- x 17
- Reluctant BXpert
Are you sure you've got the right one?
Runs away quickly due to wind-up going horribly wrong
