Building your dream BX
BMW X1
electrokid wrote: Any chance of someone finding out the VW part number ?
357-955-531 as per my earlier e-bay link.
Ordered yeaterday afternoon and dropped onto my doormat this morning, all fitted and working a treat :wink: \:D/
electrokid
Post by electrokid »
Brill - thanks Kevan :D
Also ordered.
2002 C5 HDi SX estate
just realized that almost opposite the French specialist breakers that I pass everyday ( sorry mate havent had any BX's here for a good 10 years )
There is a German specialist breakers tucked away in the back of an industrial unit ,
I wonder how much they charge for these relays ?
I keep checking back to this thread to see if the 'relay' baton is still going from hand to hand. It is isn't it? By way of an intermission here's a picture of a REALLY pretty ph.2 Valver . . .
I'll go and get myself an ice cream, some kia-ora orange juice, stretch my legs and settle back down again. :D
x 15
Re: Building your dream BX
And back to relays....bought another one from a French breakers for 5€ (with the aid of Mike E's translation!)
smiffy1071
pies are evil!
Post by smiffy1071 »
Grab me a pair of LHD headlights please???
messerschmitt owner
Post by messerschmitt owner »
I'd like a BX with the go of a valver and the economy of a dizler.
One with split rear leather seats too, in an estate, with a BX17RD badge on the back.
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Mike E (uk)
Post by Mike E (uk) »
"I'd like a BX with the go of a valver and the economy of a dizler."
you can have one with a 16V BX plus LPG conversion.
Refering to the original Dollywobbler requirements,
Increased ventilation fan airflow can be achieved by adding the second blower from an aircon car.
As someone else said, I would like my car to be as it left when it left the factory in '92 with shiny red paintwork and no scruffy bits.
However, the original can be improved on with a higher 5th gear (thanks Jaba), programmable wash wipe (thanks Mat), better stereo,improved wiring to starter motor & headlamps & ignition coil, + twin cooling fans. These I have done.
my remaining improvement is to replace the distributor with a solid state switch as fitted to the later GTIs.
Aircon would be nice, but I cannot justify the time & effort to fit it. Same with an LPG conversion.
Otherwise it's back to polishing and fixing faults as they occur.
That's pretty close to my dream BX.
Mike E (uk) wrote:improved wiring to starter motor & headlamps & ignition coil, + twin cooling fans. These I have done.
please tell me more
x 15
messerschmitt owner wrote:I'd like a BX with the go of a valver and the economy of a dizler.
Mine's pretty close, and above about 2000m altitude probably has the edge over a 16v!
1985 CITROEN BX 19GT C1TBX
2003 Rover 25 1.6i XL L33CHT
x 95
Must say after driving the TZD solidly for 2 weeks and 2000 miles I still think they are a fabulous car to drive and ride in (something my passenger would agree on), my only complaint was lack of ooooommmph, but that could be addressed by getting a TD one next time.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
x 6
It wasn't that slow Tim. You spent quite a lot of time in front of me.
Matt H
Post by Matt H »
Surely the lower oxygen-density at higher altitudes has a negative effect on a turbocharged car, or does the lower temperature counteract the effect?
I must have a go in that car of yours Mat, a 1.9TD really does appeal to me as an every-day runabout... But then again, so does a 1.9 N/A. 16v is for the weekends or special occasions.
x 15
Well, the way I look at it, the turbo will spin up until the wastegate opens (at a certain pressure) so at altitude the turbo will spin faster to achieve the same pressure, and hence volume (assuming constant temperature) of air.
This was certainly born out by the fact I didn't have to work so hard keeping up with two 16 valves the further we got up the mountains! Mulley's had a go in the past, and he seemed to like it...
saintjamesy89
My Cars: 1985 Citroen BX19 GT
Kia Venga 1.4 CRDI
Post by saintjamesy89 »
Hmm I wonder how a carbed 19 and an injected 19 would compare to your tweaked 19t-dizzle? Would be interesting to see. Well I suppose we could at the rolling road day.
2002 NIssan Micra 1.0 S CVT
2012 Kia Venga 1.4 CRDI
