breaking TZD saloon H registration
Re: breaking TZD saloon H registration
I'm after gear linkage 2 in the pic below
The one on my BX keeps popping off, presently held by tywraps
PM me how much
PM me how much
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
- Mike E (uk)
Tim, i have a box full of rear view mirrors which I could not bring myself to bin.
I'll bring one to the ccc.
Mike
Mike
- Tim Leech
- x 148
Thanks Mike! the one in the DTR doesnt reflect much anymore and wobbles something cronic.Mike E (uk) wrote:Tim, i have a box full of rear view mirrors which I could not bring myself to bin.
Mike
A bit of plumbing pipe insulation round the pipe, then cable tie it to the remains of the plastic bracket/clip - works a treat.Jaba wrote:I am after a few bits too.
Assuming it has power steering there is a clip, usually white plastic, which holds the u shaped hydraulic hose pipe that goes between the flow distributor and the pressure regulator. It sits on the LHS beneath the radiator and air filter and clips into the chassis leg. It might be tricky to remove without breaking it but I really need one. Mine is missing and the pipe makes a continual rattling noise which cant be doing the pipe any good as well as driving me mad too.
- rugmuncher
- My Cars: BX 1.4 RE, BX TZD TURBO, BX TZD Turbo, BX TXI, BX TZD TURBO
Greetings. I would love the fuel tank sender unit, (under the back seat). Please let me know price and postage to Huddersfield, Cheers.
- x 26
Not sure if I've got the terminology right but...
I would love as many of the interior A and C pillar rivets (ie the white plastic things that hold the black trim onto the A and C pillars) as possible please - think I need about 10!
3 of the boot trim side panel plastic washers/nuts that hold the panels in place
Front ashtray (if its got the smooth spring still working)
Also if you have it fitted, the rear 12v accessory socket that appears between the headphone points on the posher models.
Will PM contact details.
Many thanks
Rob.
Many thanks
Rob.
1991 Citroen BX 16v
For Rob C
The power socket on the tail of the console on my CX was a DIN socket not Cig ltr size. I have a source for these and DIN plugs... which are U looking for DIN or Cig Ltr. What size is the hole in the console. In rally cars all accessory skts are DIN and they are much superior and good quality plugs that fit both are available...
- mat_fenwick
- x 19
Agreed, and that is what is also fitted in the higher spec. BXs.Birotor wrote:DIN...much superior
- Jaba
- My Cars: BX GTi, C3 Auto
- x 82
I have tried all that Kevin. Eventually the insulation wears through and/or the cable ties break and I don't have any plastic clip at all to fix any thing to. I have made up a metal clip but eventually I end up with metal to metal rattling and I am fed up with it !!KevR wrote:
- CGATCX25GTITURBO
Could change them to rose joints, like I've done to my CX
A bit of work but worth it
missing my 1992 BX19TGD
1987 BX19 GTI
CX25 GTI TURBO CGAT 86 CGAT
19TD temp 2 Xantia estate
600 Bandit 97
ZX12R 00
1987 BX19 GTI
600 Bandit 97
ZX12R 00
Mat: I guessed it must be a DIN skt. Rob C if you don't get what you are after let me know by PM or on Forum.
would like the black plastic cover for the rad with the air divert to the intercooler.
cheers
cheers
Lovely job.CGATCX25GTITURBO wrote:Could change them to rose joints, like I've done to my CX
car has now gone although I've kept some parts that people haven't asked for -mainly body and electrical
