Timex and friends
Re: Timex
Ah yes. It does that. Randomly stops working for a bit, then randomly starts working again! Mind you, the TXD did the same the other day. French electrics!
Re: Timex
Yep - it's working fine again now
, that's one job crossed off the list
Re: Timex
Just remembered when you parked here you locking all the other doors from inside before you got out - always wondered why you did that
Re: Timex
received my doors from Kitch yesterday - he was kind enough to bring them most of the way while on a job
As expected with free doors they need a bit of work (rust along the bottom edge and under the rear quarterlights), but they're better than most of the doors on Timex.
Now I have these I'll be repairing and painting them over the winter, fitting them as I go.
Re: Timex
Started prep for the NEC yesterday. This is what I started with:
And this is what it looks like after a wash, T-Cut and application of Auto Glym plastic gel to all the plastic and rubber bits.
- Reluctant BXpert
Re: Timex
It looks great Mike, please don't pull the trigger on that gun to your head.
Look forward to seeing it on Thursday
- amazing progress in a short space of time, no longer shed of the show!
- x 17
Re: Timex
Took me a minute butCaffiend wrote:please don't pull the trigger on that gun to your head.
Re: Timex
Oh it's still a shed, just a shiny one. It's definitely it's best side there too!no longer shed of the show!
And don't worry, I shan't pull the trigger, with my luck I'd miss and hit the car!
Re: Timex
Thats pretty impressive, it even looks a completely different colour! How long did that take you Mike?
(now sadly gone)
(now sadly gone)
Re: Timex
Does look good. How much better it looks with those wheel trims on! (and after all of your hard work too!)
Re: Timex
About 4 hours on the outside, plus about 1.5 hours (so far) inside. One thing it has shown up is the different colour of the tailgate - they'd faded to similar shades! Mind you, there's so many shades of blue on it that it doesn't stand out too muchHow long did that take you Mike?
Re: Timex
Ah. The tailgate is off a later BX so is actually a different colour - though only slightly!
Re: Timex
Bought this lot at the NEC last week - 10m for £25
The old seals are tired, they've lost a lot of their spring and the metal in them is starting to fail
The new seal is at least round in section, but I hope the join at the bottom and the sharp corner at the top will seal OK - guess I'll know tomorrow looking at the forecast
Unfortunately I didn't buy enough
, so replaced the seals for both front doors and the RH rear door, leaving about a foot which I stuffed into the huge gap in the top of the other rear door.
I then turned to the radio - this is radio No.3 (No.2, a Boston kindly donated by Mickytaker hasn't been tried yet)
I wired it in, and the tape player's great, but the radio only works for a couple of minutes after being connected
I now have to decide whether to get this fixed, try the Boston, or keep looking
Finally, a pic of my 2 'hydraulic' Citroens together
Re: Timex
Just checked after todays rain and the new seals aren't leaking
Re: Timex
Good news mate. If it didn't leak after all that rain, you can probably take it to sea!
EDIT - Oops just realised where you live - you probably are already at sea
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
