Door pins and a filler neck nozzle
- x 88
Re: Door pins and a filler neck nozzle
Not needed when it's parked in a workshop
I think those drips are water that was trapped in there prior to me opening it....it was the first time I had!
1990(H) 16Valve (Rouge Furio)
- Jaba
- My Cars: BX GTi, C3 Auto
- x 83
I think its time to be creative as I don't believe these are available any more. They all seem to rust away on petrol cars. I have got mine completely covered in sealant to keep it going longer. It had rusted through and I was getting water in the tank which gave me kangaroo petrol while on the BXagon.
There was talk once of the Blingo filler being modable.
- Tim Leech
- x 150
Normally diesel Ones last ok as the oil seems to protect them better.
- Tim Leech
- x 150
- Tim Leech
- x 150
Twatting iphone!!
Tim Leech wrote:Normally diesel Ones last ok as the oil seems to protect them better.
Are you saying that they last 'Three times longer' than Petrol versions ?Tim Leech wrote:Normally diesel Ones last ok as the oil seems to protect them better.
God he loved the sound of his own voice dozen't he lol
Jaba wrote:They all seem to rust away on petrol cars.
+ Jaba had already said it
- MULLEY
I don't think its anything to do with the type of fuel being used, my money is on the fact that with a petrol you'll be opening the fuel cap up to the elements approx twice as many times as a diesel because of crap fuel economy, hence more wear & tear. So theres an incentive to get a diesel, less wear & tear, haha....but in all seriousness, can't a diesel one be fitted instead?
- Tim Leech
- x 150
Yes a td one should fit I expect?
- Jaba
- x 83
I am flattered that Tim repeats my words of wisdom not once but THREE times. Thank thank thank you Tim.Defender110 wrote:Jaba wrote:They all seem to rust away on petrol cars.
- JayW
- x 13
Afaik, the cars sharing the same filler are 16v, TZD turbo and GTI.
My TGD turbo didn't have the additional tank and i suspect the TXD turbo doesn't either.
- Tim Leech
- x 150
my 19tzd N/A had the bigger tank as does the 19TZi.
- MULLEY
My TXD N/A has the twin tank set-up
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
The 16v has a unique replacement filler neck and is not the same as the TZD/GTi. It has a smaller hole and a flap . . . presumably to make sure only the right sort of nozzle goes in. Therefore (and more for reference than anything) you can put a diesel/gti upper filler neck onto a valver, but you can't put a valver replacement neck on a diesel!
Last time i looked, i got the impression one of the C15 filler necks was very similar to the BX one, might be worth looking in Service Citroen.
