I guess in this sequence that Jury Rigging is to patch the split with duct tape, silicone and zip ties until you get home!JayW wrote:
Top radiator hose splits a couple of inches from the hose clip:
1. Repair properly: Replace the entire hose.
2. Bodge: Trim the split piece off, cut the hose in the centre and add a length of copper pipe to extend the hose to fit.
3. Botch: Trim the split piece off, stretch the hose to reach. Doing 70 on the motorway the hose tears off empties the water and cooks the engine.
The scrapper
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
Re: The scrapper
- Tim Leech
- x 150
Re: The scrapper
Vanny wrote:I guess in this sequence that Jury Rigging is to patch the split with duct tape, silicone and zip ties until you get home!JayW wrote:
Welcome back Vanny, hows married life?
Re: The scrapper
no no thats just semi temporary permanentVanny wrote: I guess in this sequence that Jury Rigging is to patch the split with duct tape, silicone and zip ties until you get home!
Re: The scrapper
Tim Leech wrote: Welcome back Vanny, hows married life?
These seemed to link together in my mind for some reason.citronut wrote: no no thats just semi temporary permanent
Martin
- mat_fenwick
- x 19
Re: The scrapper
What would these be classed as then?
- citsncycles
Re: The scrapper
Umm - I've done a couple like that
Those who were on the Challenge will remember my self grip window winder handle on the GS, while I've used a Strongbow can as a get you home repair after the exhaust broke on an AZU I once owned. If you can find them, smooth sided food cans make a much longer lasting repair though - my parents used several on a Range Rover they once owned.
