Loads of BX Spares
- Ian_Fearn
Re: Loads of BX Spares
If it doesn't work out I may be taking up your offer of help Tim!!
Over and out from me
- Tim Leech
- x 148
No worries, same goes for anyone else, I will be at the X rally all being well so can ferry bits about.
Is the front subframe a series1 bearing or series2 rubber joint to A-frames?
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
If you come across any door/tailgate seals Ian, I'll take them. Cheers.
- Tim Leech
- x 148
Mark, George has the ones off the red shed for you.mds141 wrote:If you come across any door/tailgate seals Ian, I'll take them. Cheers.
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I'd be after the towing electrics kit if it's not taken please.
What is this towing electrics kit? Is it an easy way to get towing electrics? If so, bother to being beaten to it!
- Ian_Fearn
Its a load of piggy back connectors that connect into the standard wiring loom for the rear lights. It came off my old bx 4x4.
One can never have too many seals.Tim Leech wrote:Mark, George has the ones off the red shed for you.mds141 wrote:If you come across any door/tailgate seals Ian, I'll take them. Cheers.
- Paul296
Unless of course they happen to be leopard seals and you happen be an Emperor penguin . . . then it's not such a good idea.mds141 wrote: One can never have too many seals.
- citsncycles
If you end up splitting Ian I could be interested in the headlights and diesel hydraulic pump.
Are the rubber side trims the narrow ones the fit into the indent or the wider ones?
Suggestion - maybe a couple of us could load it all up to take to the X Rally? Depending on prices, I bet you could could shift a lot of it there.
- Tim Leech
- x 148
I could take most of it to the X rally, unless Ian fancies coming along aswell?
- Ian_Fearn
I've had a sensible offer from somebody on the forum. Hilary hasn't got back to me so if your out there mate let me know asap if you want the spares otherwise I'll offer them to the other party.
