A kHz is easily achievable on the motorway on a standard petrol of all flavours
The pulleys on the drive belt are arranged so that the alternator spins at a particular max speed - ratios are different between petrol and diesel to cope with the different max engine revs. But yes - a KHz is achievable - and it's at this maximum (and with the battery at or close to it's minimum - 11.6 to 12.0 volts) that the "rated" output of the alternator occurs - all other circumstances it is controlled to an appropriate level below it's max output. didn't put that very well but you probably get the jist.
aircraft electronics was I seem to remember 400Hz.
I thought that was a power distribution frequency rather than derived from an alternator - but I don't actually know - I've designed avionics but we were just using the 28v DC supply.
I recall reading about low frequency "resonators" that operated about 7Hz being developed that were supposedly capable of causing a building collapse. Tesla was supposed to have made a breakthrough on an early one of these that was almost pocket sized.
Now you see - you've mentioned one of my heroes so now I'm bound to rabbit on a bit
Nikola Tesla and Keely before him designed resonators - and there are some anecdotes from the realms of "overtone singing" as well - that's people who are capable of producing more than one note at a time
For many years The Smithsonian museum had a sculpture of Westinghouse as "Father of Alternating Current" or somesuch description, and the brass plaque quoted a number of patents relating to 3 phase AC distribution etc - all the patents were Tesla's
And Marconi was "the facilitator" of radio rather than its inventor - most of the workings of radio were underpinned by around 20 patents - again they were from Tesla.
There was an occasion when Tesla, having left Westinghouse's employment was called back to sort out a power station problem that no-one else seemed to be able to fix - Westinghouse told him to "charge whatever he wanted". So Tesla visited the power station and chalk-marked one of the machines with a cross saying "change that machine and all will be well".
Sure enough the machine was changed and it fixed the fault - and the bill for $10,000 arrived with Westinghouse
who returned it - asking for it to be "itemised".
Tesla returned the itemised bill...
To - making a chalk mark on one machine... $1
To - knowing which machine to mark... $9,999
On reliability I still would prefer a linear psu.
Damned right - I'm in the process of replacing all the 'electronic' lighting 'transformers' in the house with real transformers - the electronic ones are just too flakey - one day I'll write some stuff about SPFMA - Single Point Failure Mode Analysis - but not today - got things to do
However perhaps not so good for Radio-Amateurs. A friend of mine hates them with a vengeance as in his words "they radiate all sorts of shit across the band".
Indeed they do... even though, I'm currenty designing-in some SMPSUs between 5W and 500W - 40khz to 150KHz. I wonder how long it'll be before I chuck those out in disgust as well
