cant you contact whoever is were the car is and ask them to get the rp No.Tim Leech wrote:Thanks Malcolm, do I need to see the car for the RP number? (its 160 miles away)
or maybe a member on here living in the area of the car
citronut wrote:here is two options for front to rear brake feed pipe dependent on rp No.,
this is for a non power steering car, and the only others listed are for ABS cars
i know you said return pipe,
95 595 681
HYDRAULIC TUBE
LONG 3035
- UNTIL RPO 04346
96 117 585
DIAM 3,5-3100
- SINCE RPO 04347
and here is a metal pipe showing under brake circuit which one end terminates at the dosour valve,
and the other end is from 4 way union at the rear sub frame for the rear suspension
96 117 584
HYDRAULIC TUBE
DIAM 3,5-3375
non of which are showing as NFP
Tim Leech wrote:Looking at the engine bay number pic there's a number above the paint code, 3805, will it be this?
That was a handy tip of mine then Tim, to zoom into that Photo shotcitronut wrote:yep that should be the rp No.
so going by that it will be this pipe
95 595 681
so going by that ut will be this pipe
95 595 681
there is one pipe out of the front to rear 4 pipes that just pligs into a rubber hose above the front sub frame, it also dose have a flair in it to help it stay in the rubber hose,citsncycles wrote:From memory it will have a union on each end, although you've worried now as all the pipes did!
