Thanks - will ring as use you suggest .The dimensions don`t look quite right ?
Richard
radiators for 1761 turbo diesel
- Tim Leech
- x 141
Re: radiators for 1761 turbo diesel
Hi Rich
I notice you are in taunton, thats where I got my 19TRS estate from, theres a Citroen Specialist down that way which may help you.
Mike Chedzoy - 01823 270666
Hi Tim
I know Mike very well but but alas nothing doing on the rad. front.
I held out and found a full metal one for my turbo diesel. They are hand made but they last a lot longer than those plastic tank ones.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Also a 16v rad looks very similar but very different. As I had someone try to fob me off with a 16v one.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Thanks David.I`m beginning to think that the 'bespoke' option may be the only solution.There seems to have been a problem with the Dutch produced NRF products which have been withdrawn ( or 'quarantined' as the UK agent put it to me ), probably due to a material/production problem.There are some cores around but these don't fit the Valeo tanks.
Best regards
Richard
Best regards
Richard
Sounds like a Valeo unit will have to be sourced.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
