End of BX life crisis
x 82
Contact:
Re: End of BX life crisis
Jaba wrote:
Vanny wrote: Getting alignment is a simple enough task, made easier with the Thatcham repair book or the Citroen Workshop Manual.
Vanny, how would the Citroen Workshop Manual(which I don't have) help ?
It has a rather long and rather dull section detailing the jigging rig (both brands) used to setup the body of a BX for repair. Normally a completely pointless section of the manual, but it this case it would allow you to put the sub frame back into place with millimeter precision as you will know exactly how the car was aligned as it rolled out of the factory. In theory you could remake the entire jigging frame from scratch if you so wished, though this would probably take the same amount of time as making a BX from panels!
Oh and with regard buying a new shell, forget it, they only did saloon shells as an after sales part, they where around £6k when they last had one, you had to pay up front, there was a 3 month (i think) lead time, and they haven't been available for 10 ish years. I did ask Citroen for one once, as a joke, but they took it seriously and tried to find one!
My Cars: BX GTi, C3 Auto
x 83
The decision is made. It is not repairable economically. And as I was going to sell it this year anyway it is now officially dead.
I am going to be parting it over the summer. The engine is a goodun as witnessed at Kitch's powerfest in March. So as I need a working engine in my Hurricane it will go in there and the rest will be stripped of anything worthwhile and then sent to local cubist.
Some of you may be interested in some of its innards, I have a collection of speedlines to move on too.
I have just worked out the stats for this car.
I bought it ten years ago for £600 with 73210 miles recorded, I have added another 33,000 miles, spent £1620 keeping it running and got an average of 45.5mpg. Cheap motoring indeed.
Probably a very wise decision; despite the well-meaning moral support IMHO if it’s buggered that bad there then they are usually buggered in a lot of other places too. How safe you would be in an RTA has also got to be considered. Making a decision just on the pictures in this thread then I would have come to the same conclusion and I am a qualified welder. A great shame but not as bad as it would be for others with only one BX.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
So 106,000 which isn't that much for a BX, but just goes to show the life of body work/structural underpinnings is not necessarily determined by miles.
My TGD did nearly 200K and the sills and sub frame mounts were pretty darned good. This was a real real work horse, treated only to mechanical maintenance. A former farmers car.
My current TZD has done 156K and went crunchy crunchy when I tried to jack it up in the exact same spot as yours failed Jaba. A west country car with the n/s constantly in mud and puddles I suspect.
Do you know the history of yours much Jaba?
Contact:
A shame, but as said, that could well be just the start of the rot. Might be interested in the gearbox...
What're the rear wing panels like on it? It may be worth cutting them off if they're at all repairable as they're getting sought after now!
x 83
To answer the questions :
Thats interesting Bandit.It came from a farmer near Barnstaple. It was always a low mileage but high rear underbody rust BX.
The rest of the car is pretty solid and undamaged as far as I can tell. Its just the backend/underside that shows up as obviously rusty. So if you want to cut anything off Mike then you are welcome.
I will be saving the rear suspension cylinders but will need to fit some faulty ones to keep the car mobile. So does any one have a holed or otherwise fubarred cylinder ? I hav eonly got one in stock to fit.
x 19
If it's just literally to keep the shell rollable, how about a couple of lengths of wood in place of the cylinders?
Thanks Jaba - let me know when you're ready and I'll do my best to come on up.
Contact:
mat_fenwick wrote:If it's just literally to keep the shell rollable, how about a couple of lengths of wood in place of the cylinders?
Surely it wooden be that easy? Arf arf.
Post by Mothman »
It is bud, Mollie is 'jacked' up at the rear with wood and looks good and is at the right ride height.
Going to be sorted though soon i hope.
x 83
That's a good idea Mat. I was going to use wood, but the hard way, ( I wood woodn't I !) by fitting a piece of dowel 33cm long inside the cylinder held in place by the sphere.
There is no correct ride height though with this one as the subframe is floating downwards as the height goes upwards.
I suppose the same could be done with wooden front strut replacements too.
