Anyone got one of these . . .
- Paul296
Re: Anyone got one of these . . .
Thanks Andy - I'll buy a new one I think (for that 'putting a brand new thing on my car' feeling )
Really? Are we talking about the same part: I just unscrewed mine from the top and screwed the new one on - no tools required.Tim Leech wrote:You need to remove the sunroof motor surround then its a 8mm socket.
- Tim Leech
- x 150
Erm didn't I fit it for you at my house?
Two screws from the overhead console and two from the sun visor mounts. Drop the aforementioned console and remove said aerial mounting nut. Job done. I think.
Not mine dearie, just the dash bulbs, which was far more complicated and I was most gratefulTim Leech wrote:Erm didn't I fit it for you at my house?
I only had to replace the plastic bit that sits on the roof though (which was the bit I assumed was being referred to, being in the picture and all) not the rubber bit it screws into.
- Tim Leech
- x 150
Hmm ok! Sure I did! The time before...
- Jaba
- My Cars: BX GTi, C3 Auto
- x 83
I replaced mine a while ago with one from eBay, item no. = 400191959580. Its not 100% the same shape but it does the job for a reasonable price.
It got damaged while digging out my GTi......
- x 88
1990(H) 16Valve (Rouge Furio)
- Paul296
I think Tim and I must be suffering from some sort of mass delusion? I remember watching him . . . replace your aerial!?Caffiend wrote:Not mine dearie.Tim Leech wrote:Erm didn't I fit it for you at my house?
Onset of dementia on my part then probably
- Mike E (uk)
Peugeot 406 has a similar part, just the rod is shorter.
I have one of the above available if Jane doesn't want it.
Mike
Mike
- MULLEY
Isnt the confusion about 2 things:
1) Just replacing the ariel, which just screws in
2) The ariel base, which requires the removal of the motor etc
So which job do you need doing Paul?
Good piccy by Jaba, worthy of being on the front page of the site
