Pigeon Restoration
- Backslash Bandit
- My Cars: Cars
Re: Pigeon Restoration
Mk 1s are quite, if not very cool. I dearly wish I had my dads mk 1 Sphinx Gold 19RD B148UYD but there you go,my sister traded it in for a fooking Mondeo.
Anyway, I hate cars
Anyway, I hate cars
Many a true word spoken in jest Bandit!!BX Bandit wrote: Anyway, I hate cars
I also hate cars (apart from when i love them, but mostly hate)
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
1985 CITROEN BX 19GT C1TBX
Stinkwheel wrote:Many a true word spoken in jest Bandit!!BX Bandit wrote: Anyway, I hate cars
I hate mine at the momentt, well one of them, and its not a Citroen.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
morris or VW then Tim?
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Backslash Bandit
- My Cars: Cars
The Morris?
I've put more effort into this car than any other, the steering I can handle, but the smokey emissions I'm putting down to poor compression which is from the piece of crap I bought as an excuse for a cylinder head and more fool me for not paying close enough attention to the valves/seats.
Stinkwheel wrote:morris or VW then Tim?
I dont actually own a VW, its a company car.
The brakes on the Morris have been a right ball ache, sometimes they work, then not. Ive replaced the master cylinder, brake linings, fluid and bled it more times than soft Mick!
It has a remote servo fitted which we think is the issue, ive a friend who owns a brake flaring tool who is coming down to bypass it to see if thats the issue as its very strange the way it behaves.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- Backslash Bandit
- My Cars: Cars
Make sure the vacuum line to the inlet manifold isn't cracked or jubilee clips loose etc....
If you are going to keep the car long term, the Morris marina brake discs are a worthwhile conversion.
BX Bandit wrote:Make sure the vacuum line to the inlet manifold isn't cracked or jubilee clips loose etc....
The servo kit is new, but i fitted a new vac pipe etc just to make sure, it seems to be letting air into the system. Ive bought a brake light switch and flexi's too.
My mate has the same car with the original drum set up and for my style of driving and its 48bhp they do the job fine (when they work properly that is).
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Tim Leech wrote:Stinkwheel wrote:morris or VW then Tim?
Oi !!!!
I must have a sit in a moggy to see if I err fit and could still drive one ,
a really nice one needing a little work was on ebay last week £1300 buy it now and it didn't sell.
Mickey taker wrote:I must have a sit in a moggy to see if I err fit and could still drive one ,
Theres a surprisng amount of room Mick, I have to move my seat quite a bit forward to reach the pedals!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- Backslash Bandit
- My Cars: Cars
I'm sure your mate will sort you out but what do you mean by letting air into the system?Tim Leech wrote:BX Bandit wrote:Make sure the vacuum line to the inlet manifold isn't cracked or jubilee clips loose etc....
The servo needs a 'vacuum', fed by the tube from the servo to the inlet manifold. It needs to be air tight otherwise it won't pull a vacuum and you'll lose the effect of the servo.
The servo seems to working ok, but also seems to be letting air into the brake lines themselves.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Servos usually are sealed around the main body by a big o-ring. They have been known to suck in air past them.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Stinkwheel wrote:Servos usually are sealed around the main body by a big o-ring. They have been known to suck in air past them.
Were going to isolate it and see if it makes a difference, if not I will reconnect it and start changing wheel cylinders!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
