with the ride height to low she will feel stiff whoooops i mean firm,
if this is a direct result in fitting the new shorter drop links, then yes you will need to adjust the H/C link clamp on the anti roll bar,
BUT BE WARNED HYDRAULIC CITROENS CAN AND HAVE KILLED,
THE CAR NEED TO BE UP ON A CAR LIFT PREFERRED, BUT 4 CAR RAMPS WILL SUFFICE
the slightest movement of the clamp will give a lot of height change, so inly move it a slight bit and lock it off each time to messure the new height
drop link
Re: drop link
Re: drop link
Mr BanditBX Bandit wrote:Hmmm, I need to shut up then, I forgot about the h/c being connected to the arb. I'll stick to drinking cider - it's what I do best
we cant know every thing, i know nout about drinking cider
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: drop link
The point is I should of twigged about the H/C on the ARB....I'll blame the weather, I've hardly touched my BX work for two weeks!
Re: drop link
what your not going to blame the ciderBX Bandit wrote: I'll blame the weather, I've hardly touched my BX work for two weeks!
Re: drop link
I do Malcolm!!citronut wrote:Mr BanditBX Bandit wrote:Hmmm, I need to shut up then, I forgot about the h/c being connected to the arb. I'll stick to drinking cider - it's what I do best
