Breaking TD Estate
Thread Bear
Re: Breaking TD Estate
Post by Thread Bear »
Jaba wrote:
Thread Bear wrote:Hi 'tis I
When you scrap the car are you taking wheels off it? /quote]
I will check out the interior lights to see if they are serviceable and that I have one in stock for myself.
I am keeping the wheels and have put spare scrap ones on the car ( these might be better than yours though, two are alloys). The originals are alloys with good tyres on to use as my other tyres in use wear out. After that they will be available.
Did not notice they were alloys. Not the greatest fan of them on a daily car as wheels attract the dogs and that leads to corrosion on the bead joint and slow punctures with alloy wheels. The steel seems more resistant. So I will duck collecting alloys I think, thanks. Someone else might nibble. I did wonder if the Pug 405 used the same wheel but I have a sneaking suspicion they might be 1/2J wider as the Pug is heavier. There are 5 Pugs in Junky Haynes at the moment (no BX, so don't get excited at the back) and I know Rodney pretty well so normally get a reasonable deal. I was going to go over and take some common parts as I think the Pug 405 are finally mostly falling out of service. Good strong car, but without the BX bounce. Most of the engines have been played with and lost parts but there might be something of use on the rebuild if you get stuck.
Rob Viner is going to help me do cambelt and braces on his ramp. Good independent mechanic in Thrupp, Faringdon version, you might have come across him as he used to be a BX man. Good chance to check out other issues. We'll see how we go on rim looking. Hope to see you at Wickstead anyway.
Mike E (uk)
Post by Mike E (uk) »
If you send Jaba your dog bitten wheel, he could swap them and still move the donor car about.
benben10
Post by benben10 »
yeah i thought about that but then i cant get to work.... hmmm halfords aftermarket one?
Thread Bear
Change it at the weekend's rally and be the great attraction. =D> I already pulled Jaba's wheel off so that is loose. Cross his palm with silver.....
Reluctant BXpert
Post by Caffiend »
Jaba wrote:Yes , its a good one Sandre so I can be your spares bitch. Its no charge for services to the BXC.
(...) Will speak on Saturday.
Most kind, thank you so much :) (and sorry for the horribly delayed response, I missed that this thread went over onto a new page :oops: )
I'll sling a bit extra into the NEC pot in lieu then, if you're happy with that. As far as collection goes, will be at Stratford if you or someone in your geographical vicinity will also be there. Alternatively, I have friends/family in Wilts and am sure I can make a road trip via Didcot ... lemme see what we can do.
My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around
x 70
Post by rutter123 »
hi, i would like the rubber flexi air intake hose, as you look at the engine its to the left and fits between the 2 plastic pipes just above the top engine mount. if its not split. and possibly part of the o/s/f chassis member
x 26
benben10 wrote:yeah i thought about that but then i cant get to work.... hmmm halfords aftermarket one?
Are you coming to the National on Saturday ? If so we can do a wheel swap there.
The Joy of BX with just one Citroën to my name now. Will I sing Bye Bye to my GTI or will it be Till death us do part.
x 26
rutter123 wrote:hi, i would like the rubber flexi air intake hose, as you look at the engine its to the left and fits between the 2 plastic pipes just above the top engine mount. if its not split. and possibly part of the o/s/f chassis member
Sorry the hose is not a good one as its split already and bandaged up with ductape.
Not sure what chassis part you need. Bear in mind I want to keep the car's mobility unaffected up to cubing time.
x 26
News,good and bad.
Sandre I have removed the RHF wing and will have it on Saturday. It will be for EXCHANGE only with your damaged wing so that my scrappers will be happy that, as stipulated, it is is a complete car.
So I hope we will be able to do the remove/replace at Wicksteed.
x 26
There is no need to do that. You are doing more than enough as NEC organiser so I think that there is no need for you to finance it as well.
Reluctant BXpert
Post by Caffiend »
Fabulous, thanks J - of course, presumed you would need the damaged wing - will take Tim up on his kind offer of replacement, and get in the way watching ;P
x 70
Post by rutter123 »
hi jaba i will need approx the first 6 inches of the o/s/f corner inc chassis rail.
1985 CITROEN BX 19GT C1TBX
x 107
Good to see you today John, new wing fitted!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
